From this to this
DRW are good for heavy loads and towing. They are not good for parking,driving on city streets and going off road. I have some property in the mountains,and the road is bad,and the fields get soft in the spring. Many times I would not go there because I was afraid of getting stuck . The truck will now go without giving it a thought. It rides much better and way easier to park . It still tows my toy hauler good,but it was more stable when it was DRW. It works better for me as SRW. I do have everything to convert the truck back if I would ever want to.
I have a heavy-ish 5th wheel and have had both DRW and SRW trucks. In my experience, the dually would stay a little better planted when battling strong crosswinds. Otherwise, I like a SRW better in every other way.
unless you have a massive 5th wheel or a particularly heavy slide-in camper, I really don't see the need for a dually. They are annoying to park in town and are brutal offroad. They often can't go in the automatic carwash, get less fuel economy, have 2 more tires to replace at a time, with fewer tires to choose from and on top of all that, have less traction on snow and ice.
unless you really need a dually, I'd recommend staying away from them. I sure as hell wont be getting another one.
Eugene, he just converted it to a srw.
He kept the parts.
That's an ample amount of pride in a vehicle to just pull the chain and do what you did. Beautiful rig, beautiful job.
When I first started following this thread I thought you were nuts. Your explanation for the venture is on point and I have the greatest respect for your enginuity and effort to make "yours into yours". (took me 3 shots to get enginuity right, all right I'll have another)
Most people would go the other way. First for me.
I've had both and understand completely that they may be better for a long haul +/-, but in terms of a daily, they are a lil cumbersome.
Well done.
Denny
He kept the parts.
Well done.
Denny
Denny,
I should have figured that out by the pictures, but because of the work involved I assumed sale and purchase keeping some of the accessories. So rephrased: It was and still is a beautiful truck! And I'm sure he fully thought it out before the conversion.
The rear axial is wider on a dually. I think 4" but never measured it to be sure how much. The front hubs just have a spacer that I removed so I could mount regular wheels. The bed has the fender flairs and appears to bed a standard bed under them. I did not want to fill all the holes where the flairs were bolted to the bedside ,so I just replaced it. This also gives me a axel and bed if I would ever have the need to go back to dual wheels. Thanks for the compliment on my truck.
Thanks ,I appreciate all the compliments,This old truck has been around 18 years, For over 10 years it was never driven in the winter and used to tow with. I never hauled much in the bed because I did not want it beat up so,I would pull a trailer when I needed to haul things. Then I got to a point that I just as well use it up and buy me a new one some day . In the spring I began shopping for a new truck and brought a couple home for the night to check them out. I just could not make myself spend the amount of money it cost for a new truck. I could afford it ,but it's a lot of money and my old truck is still in good shape and only at 120,000 miles on the clock. I dicided to spend a little on it to make it work better for me and keep it. My son was dis appointed because he was going to get it.lol.I am now thinking the old truck will be back inside this winter and I will be drivering and old beater .
Nice conversion. The only thing that stops me from thinking about getting the 5th wheel I really want is having to drive a dually I really don't want.
I'll get a lighter 5th wheel and stick to a SRW when I pull the trigger. I've driven duallys, and really don't like getting groceries or sight-seeing in them. Do love the stability with a heavy load though.
