Cutting 428 heads
Old Sep 21, 2003 | 08:41 PM
390fourby's Avatar
390fourby
Cutting 428 heads
My heads are pitted on the exhaust manifold side. I was just wondering if there was a spec as to how much I can have cut off.
Old Sep 24, 2003 | 12:09 PM
William's Avatar
William
Cutting 428 heads
Pitting caused by corrosion is normal. It can be severe and not affect sealing of the manifold or header. I clean up the mating surface and have a look, If I think the pitting will cause an exhaust leak I'll use an epoxy or weld the head. For regular old FE heads replace them.
