Need key-on powered wire
Old Jul 3, 2018 | 06:47 PM
rsylvstr's Avatar
rsylvstr
yes I searched.
Installing electric exhaust cutout switch by my right knee.
suggestions on best place to ground and where to access power?
thanks in advance before I start pulling panels.
Still have to figure out the best best way to get the wiring into the cab too.
Old Jul 3, 2018 | 07:44 PM
zxwut?'s Avatar
zxwut?
Knowing what you're driving would be helpful.
Old Jul 3, 2018 | 08:35 PM
rsylvstr's Avatar
rsylvstr
Good point. In my signature which I guess you can’t see
2013
F150
Lariat
SCrew
5.0
4x4
Old Jul 4, 2018 | 03:35 PM
marang's Avatar
marang
Originally Posted by rsylvstr
yes I searched.
I just ran some power and ground wires into the cab yesterday. On the passengers side inside engine bay there's a rubber boot against the firewall that a bunch of wires go through. I cut a slit in that boot then ran the wires through it into the cab. Over on the passengers kick panel where the wires will end up is a ground lug just above the fuse panel. I used the power lug inside the engine bay that's under the fuse panel cover. Hope I explained this well.
Old Jul 4, 2018 | 04:09 PM
rsylvstr's Avatar
rsylvstr
thanks. The power lug as in the big one with the nut?
Old Jul 4, 2018 | 04:48 PM
marang's Avatar
marang
If you're looking at the engine bay with the fuse panel off it's the lug on the passengers side with a 10mm nut on it .there should already be 1 or 2 wires connected to it already.
Old Jul 4, 2018 | 05:19 PM
rsylvstr's Avatar
rsylvstr
That’s the one. Thanks!
twack
Sep 19, 2022 08:33 PM
Baldicon
Apr 8, 2019 06:00 PM
Bill Moulton
Aug 26, 2018 11:02 AM
nwfuel
Apr 16, 2018 06:06 PM
blkbest
Feb 5, 2010 05:04 PM
