Engine fan testing
Old Jul 2, 2018 | 08:57 PM
1999-F150's Avatar
1999-F150
Engine fan testing
Hey all, is there a way to check the engine fan clutch? I an not sure if the clutch is working. Do you know at what temperature the clutch engages? Thanks for the help!
2006 explorer 4.0 4x4
Old Jul 2, 2018 | 09:59 PM
Spaznaut's Avatar
Spaznaut
Is it over heating? Usually you let the engine overheat a little and then turn it off. Then go out there and try to turn it and see if any resistance. Usually you can hear the fan spinning faster when the engine is hot (around 210-220) Remember most thermostats don't open up all the way til 220.
Old Jul 9, 2018 | 03:55 PM
1999-F150's Avatar
1999-F150
not overheating, but the ac is not cold when you are stopped or moving slow. The temperature will not go over 206*
Old Jul 9, 2018 | 04:25 PM
1999-F150's Avatar
1999-F150
this has an electric fan clutch. With the engine off won't it spin freely regardless of the temperature?
Old Jul 9, 2018 | 05:24 PM
1999-F150's Avatar
1999-F150
Should the fan come on when the ac is turned on?
jpcjguy
Jul 7, 2010 12:03 PM
webster
Jun 5, 2006 11:37 AM
stockernavstar
Mar 5, 2006 03:50 AM
ChucksVan
Aerostar
Dec 10, 2004 09:31 AM
Dan76'F100
Jun 11, 2003 10:20 PM
