2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Where can I get the fifth wheel prep package? HC3Z-5F057-B
Old 07-02-2018, 01:26 PM
saucemann's Avatar
saucemann
saucemann is offline
Old 07-02-2018, 02:34 PM
h20camper's Avatar
h20camper
h20camper is offline
Try your local dealer. Its heavy as you'd expect so buying online would be expensive due to shipping costs.
Old 07-02-2018, 02:39 PM
saucemann's Avatar
saucemann
They seem to be back ordered around the Houston area, that's why I was asking for alternatives.
Old 07-02-2018, 02:48 PM
h20camper's Avatar
h20camper
Ah....sorry. Problem is most online Ford sites will take the order and later tell you its back ordered. Try Fordpartsgiant.com
Old 07-02-2018, 03:04 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
MSRP: $695.00 // autonationfordwhitebearlake.com online price: $535.15
Old 07-02-2018, 03:06 PM
h20camper's Avatar
h20camper
Plus $102 shipping.....
Old 07-02-2018, 08:03 PM
petei's Avatar
petei
petei is offline
I use to have problem order but that was when Ford just come out with the 2017.The dealer told me is in back-order, but when they got to order another one because the first one parts missing, they find one in couple of days.So just push it talk with the manager they got it.
Old 07-03-2018, 07:43 AM
7591250sd's Avatar
7591250sd
7591250sd is offline
I believe Reese makes the oem prep package, see Item # RP30126 at etrailer.
Old 10-29-2018, 03:56 PM
BK39's Avatar
BK39
BK39 is offline
Says that part # fits the 11-16 trucks, but not confirmed on 17+. Anyone go this route and can confirm it'll work?
Old 10-29-2018, 04:12 PM
landman873's Avatar
landman873
landman873 is offline
Just get yourself a B&W its cheaper. That's what i did with my 350. It was simple and easy. Plus i didn't have to take the bed off. I believe the factory ford one the bed has to come off or raise up several inches
Old 10-29-2018, 09:31 PM
jrwinger's Avatar
jrwinger
jrwinger is offline
I bought mine from levittownfordparts.com. It took a few months for the backorder to ship, but it all came including the bed wiring harness.
Here is my invoice:
1 x Ford Super Duty Hitch Prep Package - 5th Wheel/Gooseneck (HC3Z-5F057-B) = $535.15
Sub-Total: $535.15
FedEx (Fedex Ground): $124.32
Total: $659.47
A local 4x4 shop installed the entire package for me for $200. That put me out the door for $859.47. The cheapest ford dealer in my area bid me over $1100 for the parts & labor. The most expensive dealer wanted close to $2k. You do have to remove the bed to install the factory 5th wheel prep, but it's worth it in my opinion. the B&W stuff is OK, but I wanted the sleek "puck" system that the factory unit offers.
If you're OK with waiting for the backorder to ship, it's well worth it to do the factory ford option in my opinion. If you have the equipment to install it yourself you can save a few more bucks.
Good luck!
Old 10-30-2018, 09:16 AM
petei's Avatar
petei
petei is offline
The only equipment(tool) you need to install it is a special socket for the bed bolts other then that hand tools is all you need.
Old 10-30-2018, 09:53 AM
N2dunz's Avatar
N2dunz
N2dunz is offline
Remember the bed bolts are a 1 time use per Ford.
At least that is what I have been told?
Old 10-30-2018, 10:10 AM
BK39's Avatar
BK39
BK39 is offline
I did the OEM bracket on my 17. Put the exact same bolts back in it, torqued to spec, have't had any issues in 2 years plus. I'd like to stick to the OEM unit for this 19, for ease of swapping the hitch from truck to truck. I was open to the Reese, assuming it was similar, but can't confirm it's fitment on the 17 plus trucks. I'll keep looking around.
Old 12-14-2018, 06:32 PM
BlackF350-2's Avatar
BlackF350-2
BlackF350-2 is offline
BK39, Did you ever find a factory hitch or confirm if the Reese hitch will fit on 2017+ trucks? I'm trying to find a factory hitch and all the parts sites are starting to say it's discontinued.
Thanks
Quick Reply: Where can I get the fifth wheel prep package? HC3Z-5F057-B
