Ok, got another one...DPF potential issue
Old Jun 30, 2018 | 08:37 PM
Trash Hauler's Avatar
Trash Hauler
Over the past couple months I have noticed some abnormal behavior with the regen cycle. Regen has been cutting off about 40% then drops to about 20% with the residual heat. Soot would then build back up quicker than in the past, especially when towing a trailer with EGTs running plenty warm for a passive regen.
Several people indicated similar behavior during the winter but I did not have that problem.
Anyway, I ran a static regen using FORScan this evening. DPF was at 95% when I started the truck. It climbed to 101% while it warmed up. FORScan static regen started as it should (note, this was my first time doing a static regen). It ran for about 5 minutes then failed due to an “unspecified abort criteria”. Then, the soot level dropped to zero on the screen and 12% per forscan.
Something obviously isnt right.. No codes or anything to diagnose.
Ideas?
Do I reset the learned DPF levels and force the PCM to relearn?
Or leave it alone and see if a code pops up eventually?
I don’t want to delete at this point but if the DPF does fail and the extended warranty wont cover it, then the rocket will fall off. Just money I dont want to spend.
2013 F350, stock configuration with 64,500 miles.
Bob
Old Jul 1, 2018 | 11:31 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Bob,
I have noticed in recent versions ForScan does stopstop no reason in static Regen.
I will post up a link to a version I know works.
I have been getting weird percentages as well. I recently did a static Regen, then reset parameters.
It settled back in after one fullnregen cycle.
Keith
Old Jul 1, 2018 | 09:14 PM
Trash Hauler
Originally Posted by ZooDad
Bob,
Keith
Thank you Keith. I figured you would have some insight into the matter. I will reset the learned values and see if it straightens out.
Bob
Old Jul 2, 2018 | 03:59 PM
ZooDad's Avatar
ZooDad
Bob,
Sent you a PM
Keith
Old Jul 3, 2018 | 07:24 AM
Painted Horse's Avatar
Painted Horse
I've got over 250,000 miles on 6.7L engines and I pretty much ignore the regens, It's just something that happens in the background.
Old Jul 3, 2018 | 07:42 AM
MPawelek's Avatar
MPawelek
Your wish is fulfilled. I have erased my original post.
Old Jul 3, 2018 | 04:12 PM
Trash Hauler
Originally Posted by MPawelek
The original post is a example of a situation which once again leads me NOT to download the ForScan program to my laptop. So much hand wringing and concern over a system that 99% of the time takes care of itself in the background. I now realize why Ford has taken some gauge options off the dashboard. Yes, some of the ForScan options are interesting to change but for me I do not need the drama of worrying constantly about regeneration and filter percentages. I am glad my 4 diesel tractors do not display all this information and run perfectly all the time without me knowing what they are doing behind the scenes.
Yes, ignorance is bliss is one method of maintenance. Others prefer to be proactive with maintenance and knowing what is going on with the vehicle. Trending is one such method and it involves tracking what happens and looking for changs in normal behavior.
Its really awsome to know that your tractors run perfectly. Thanks for hijacking the thread.
Old Jul 7, 2018 | 07:25 AM
The Bone's Avatar
The Bone
Trash hauler:
Information in the wrong hands is dangerous. So glad you feel comfortable changing the parameters that Ford engineers installed in your truck.
Thread title said it all Potential Problem. So you need to fix a problem that doesn't exist.
Just saying
Ltngdrvr
6.7L Power Stroke Diesel
61
Mar 27, 2016 11:47 PM
HKusp
18
Jul 17, 2012 08:32 AM
Sparkplugless
24
May 26, 2011 04:11 PM
Kep4
Jun 9, 2009 04:33 PM
