Hub interchange
Old Jun 28, 2018 | 05:20 PM
aqqus's Avatar
aqqus
Hub interchange
I'm trying to help a friend. He has a 78 ford Motor home with 16.5 rims, wants to switch to 16's. Has access to a 91 F350 dually with 16's. He found out rims will not swap due to hub pilot issue. The question is can he swap the hubs from the 91 to his 78 to use a more available hub pilot rims?
Old Jun 28, 2018 | 08:36 PM
1320stang's Avatar
1320stang
Nope, my F100 wouldn't fit my Cragars and I machined the hubs down, he might be to do that.
Old Jun 28, 2018 | 09:15 PM
aqqus's Avatar
aqqus
Can't find 16" lug pilot dually rims in our area, only hub pilot wheels. The 78 does not have large enough hubs to pilot the new wheels. He will try swapping hubs off the 91 he got the wheels from tomorrow. Research shows the 78 and 91 use the same bearings and rotors on the front. Rear will be questionable, the 91 may have a sterling. Won't know until he crawls under tomorrow.
Old Jun 28, 2018 | 11:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What is the Motorhome, a Class C? If so, it's probably an E350 (Econoline) Cut-Away.
E350 & F350 with DRW use the same hub & rotor assy's.
Old Jun 29, 2018 | 05:18 AM
aqqus's Avatar
aqqus
Yes it's about E350 cut-away
Old Jun 29, 2018 | 05:21 AM
aqqus's Avatar
aqqus
Numberdummy, what about the rear? If they are both Dana 70 would they be the same hubs? Possibly same brake drums?
Old Jun 29, 2018 | 08:22 AM
NumberDummy
E350 would have the Dana 70, F350 would have a Sterling 10.25" but the type of rear axle has nothing to do with the brakes.
E350 uses a different hub and drum assy than the F350.
02250sd
Jun 1, 2015 09:01 PM
icentropy
Sep 8, 2013 09:35 AM
rockcrawler_101
Jun 2, 2013 02:27 AM
Malahki
May 8, 2011 11:33 AM
jimandmandy
1983 - 2012 Ranger & B-Series
Jan 21, 2009 06:33 PM
