Sponsored by: Real Truck
HELP
Old Jun 27, 2018 | 12:40 PM
Hunterbaney99's Avatar
Hunterbaney99
HELP
Ok guys I really need help with this. So while doing a tune up on the truck I pulled my abs 30 amp fuse and dropped it. Well the light came on so I simply replaced the fuse. Light is still on and the truck is shifting really hard, no speedometer. I was told to replace the vss on the rear diff and it should fix the problem. Well I replaced it and still nothing. Idk what else to do, anybody have a similar problem? How did you fix it? Truck is a 99 f250 super duty v10
Old Jun 27, 2018 | 01:05 PM
Mike1's Avatar
Mike1
After reading up on it a little bit, I found that some guys are having the code cleared and others are just removing the positive cable and letting it sit for a few minutes before they reattach it. they're saying everything starts working and haven't had problems.
Old Jun 28, 2018 | 12:20 AM
9rudy9's Avatar
9rudy9
I agree with mike 1, disconnect the battery put the fuse back in and then power up. 95 views and 1 response. Good job Mike 1
Joshua A. Gaudette
Jul 15, 2023 07:52 PM
Landandlakes
Oct 13, 2007 05:59 PM
Landandlakes
Sep 26, 2007 08:20 PM
uncbeatncsu
1997 - 2003 F150
Apr 13, 2004 03:27 PM
