Sponsored by: Real Truck
Blend door
Old Jun 26, 2018 | 08:45 AM
myfar's Avatar
myfar
Blend door
I have read many posts and responses on different forums concerning this topic but have never seen a post with my symptoms. I have a 2003 F350, 7.3L, automatic, 4X4. When I back out of the driveway in the morning, after I remove my foot from the brake pedal, I hear the blend door close or open, which ever it does for AC, and I have good cold air from the correct vents. It takes a few starts and stops to get on the open road and once the starts and stops end it starts blowing hot air. If I come back into traffic and have to apply my brakes for slow downs or a traffic light, then upon moving again, I'll hear the door close again and my cold air is back. My thinking is that the on/off switch is built into the vacuum pump and it's limits have changed slightly. I may also have a small vacuum leak so when driving with no stops my vacuum drops a little allowing the blend door to open at least partially. Then when I apply the brakes, the vacuum drops low enough to turn the vacuum pump back on and everything works correctly again. Does this make sense to anyone?
sftbalnerd
Sep 20, 2017 04:23 PM
Varro
Oct 10, 2016 06:21 PM
Vinford
Jun 6, 2015 09:20 AM
wresleu
Jun 8, 2009 04:35 PM
evan250
Sep 18, 2004 04:54 PM
