Factory vs Hellwig rear sway bar
Old Jun 26, 2018 | 04:03 PM
nuctrooper's Avatar
nuctrooper
Originally Posted by jaxf250
I like the ride improvement the bigwig bar made in the rear, and now after reading this I am thinking about the front too - what p/n did you use on the front? 7712? My '17 F350 Lariat Ultimate is SRW/CCSB/PSD/4x4/no lift
I'll cut and paste this from my post on a different thread on the topic since you're considering getting a second hellwig. Just for consideration:
"On my '03 F350 SRW, I ran for years without the rear sway bar. Lots of off road (6" lift on 37s). Plenty of articulation (for a LWB truck). When I got a TC, I put the factory sway bar back on. Worked OK for the TC, though still had quite a bit of roll. It wasn't too bad off road (unloaded), but I could tell the sway bar was there. Could pick up a tire fairly easily when off camber, but it was still usable.
The sway with the full size TC was a little disconcerting at times, so I went with Hellwigs front and rear. Easy install. Night and day difference with the TC. Much more stable, less sway, more controllable, more pleasant to drive when loaded. BUT - when unloaded, I could pull one front tire onto a rock the size of a cinder block, and the same side rear tire would come off the ground. The articulation was horrible, and its unloaded off road performance sucked. We boondock in the mountains a lot, and fire roads/primitive roads were fine with the TC loaded, but unloaded I could count on tires off the ground."
Old Jun 26, 2018 | 08:53 PM
Sf jakey's Avatar
Sf jakey
Thanks guys. Ordered the factory bar
Old Jun 26, 2018 | 09:51 PM
jaxf250's Avatar
jaxf250
Good information thank you for this.
Old Jun 26, 2018 | 10:06 PM
jakematic's Avatar
jakematic
Thanks to all the contributors here. Something I've been considering as well since mine doesn't have the rear sway bar.
Old Jun 27, 2018 | 04:05 PM
cficare's Avatar
cficare
Good for you and good luck. I hope it doesn't leave you wanting for more. Then again, suspension modifications can be a very personal affair depending on one's preferences. After installing my Hellwigs, I swapped out the shocks with Rancho adjustable. I now find I'm really enjoying the truck more with a suspension that feels softer, but rolls sideways very little when cornering.
Old Jun 30, 2018 | 02:16 PM
cficare's Avatar
cficare
BTW, if you're near southeast VA, I just listed an extra pair of Hellwig swaybars in the classified section.
https://www.ford-trucks.com/forums/market/1546014
Old Oct 17, 2019 | 10:20 PM
Gyukonrick's Avatar
Gyukonrick
Does anyone want to sell their factory rear sway bar? I am interested.
Old Oct 18, 2019 | 05:53 AM
17 Oaks's Avatar
17 Oaks
(my wallet is still recovering from the custom audio install a month ago, but hey, the front bar just HAS to be upgraded to MATCH the rear! Yeah, that's it! LOL... this forum costs me $$ ;-) LOL....
I addded the hellwig big wig on the front and its just not needed unless you run your Superduty at gymkhanas. It a teeth rattler, but you can run in gymkhanas for sure.
Old Oct 18, 2019 | 07:11 AM
VEW's Avatar
VEW
Rear factory sway bar
Q
What model year truck do you have? I recently replaced my factory sway bars with Helwigs so I have both the front and rear bars .They came off a 2003 F-350.
Old Oct 18, 2019 | 07:13 AM
Gyukonrick's Avatar
Gyukonrick
I have a 2018 F350.
Old Oct 18, 2019 | 07:52 AM
VEW's Avatar
VEW
Yea, don’t think they’ll fit.
Old Oct 18, 2019 | 12:02 PM
cficare's Avatar
cficare
Reading this thread made me realize I need to update my statement. Sold the Hellwig front bar and still have a new-in-box Big Wig rear bar available.
Old Oct 18, 2019 | 03:12 PM
  #28
Gyukonrick's Avatar
Gyukonrick
How much are you asking for it? I live in Canada.
Old Oct 18, 2019 | 03:25 PM
  #29
cficare's Avatar
cficare
After receiving a few PMs, I should clarify that my previous post said, "If you're near southeast VA ..." Meaning: I'm not going to ship this thing. Sorry, guys.
Old Oct 19, 2019 | 12:53 PM
  #30
Brent376's Avatar
Brent376
I'm in the PAC NW. I have factory and will upgrade to BigWig
