1991 F250 Engine and gauges stop suddenly?
I need some help on solving a problem with my electrical system. I live in the rainy Pacific NW, my 1991 F250 Lariat 460ci gas runs OK, always seems to run when I need it. Picked up a couple yards of rock, headed down road. About 10th of a mile later the truck stops running. The gauges don't work, and the windows don''t work all the keyed accessories don't work, and no power to the solenoid from the switch, but the headlights and brake lights and dome lights work. AC has never worked since I owned it and the heater fan only worked when it was on high. I turned the heat on just before the electrical failure. The starter works fine when I jump the solenoid. Checked all the fuses and replaced the ignition switch actuator on the steering column. I did check and replace the questionable fusible links. Still nothing. What is my next logical check point? Thanks for any suggestions or past experience with a similar problem.
Check Fuse Link G, (Brown Link) Yellow wire/s, that feeds your Ignition Switch, it's up by your battery.
Check that Yellow wire from the Ignition Switch back to the Fuse Link up by the Battery.
Check for Battery voltage on the Yellow wires connected to your Ignition Switch.
CH67guy1
06-10-2013 01:26 PM
93 r1
25
06-18-2003 05:33 PM
