Straight pipe 7.3 question
Old Jun 21, 2018 | 12:55 PM
TesticleFestival's Avatar
TesticleFestival
Im new to the diesel world, bought a 99 f250 7.3, someone once told me (a chevy guy) that if you were to straight pipe your truck you would need to tune it because it wouldnt run right. I would guess that what i was told is false but like I said I am new and dont know for sure.
Old Jun 21, 2018 | 01:26 PM
z31freakify's Avatar
z31freakify
Contrary, it will help your truck spool the turbo a bit quicker.
Old Jun 22, 2018 | 12:12 AM
'88 E-350's Avatar
'88 E-350
If you straight pipe a gas motor you might have tuning issues. With a diesel the only issue will be you being the obnoxious guy that all your neighbors dislike.
Old Jun 22, 2018 | 01:00 AM
Mike321's Avatar
Mike321
Mine is straight piped diesel and I live in San Francisco. My neighbors don't complain -- drive it like you live there and nobody will complain. The point of a straight pipe is not to "impress" your neighbors, it is extra power when you need it.
Old Jun 22, 2018 | 06:51 AM
schlepprock250's Avatar
schlepprock250
4"turbo back Magnaflow exhaust. I just went from a muffler back to straight pipe, there isn't much sound difference. When you get in to it is the only time you can tell.
Old Jun 22, 2018 | 07:37 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Yes, the information is inaccurate. You would actually help the motor by allowing it to breathe easier.
Old Jun 22, 2018 | 07:50 AM
F250_'s Avatar
F250_
When my son cut off his muffler on his 7.3 several years back, his truck sounded like a diesel version of a ricer f@rt can... not a good sound note at all. For a truly straight-piped approach where the length of the exhaust pipe remains intact, it might sound a little different, maybe better. Regardless, after hearing my son's truck with his approach, straight piping is something I would never consider doing to any 7.3.
Old Jun 22, 2018 | 01:42 PM
brian42's Avatar
brian42
Veteran: Navy
As everyone has said there's no tuning modifications required for an exhaust change (of any type). Same goes for the intake.
You don't really need to worry about tuninig unless you are going with non-original injectors (oversized, single shots, modified nozzles, etc.). Tuning can take advantage of some modifications but is not necessary in most applications.
Old Jun 22, 2018 | 03:00 PM
DieselDenny's Avatar
DieselDenny
Mine is straight piped with duals, split after what once was the muffler.
Not loud until you get into it and you hear every cylinder fire, but not a neighborhood waker. Very quiet at idle.
No drone and it is respectably noticed when your into it.
Denny
Old Jun 22, 2018 | 03:37 PM
F250_'s Avatar
F250_
Denny
Denny... just curious... is the whole setup still at the stock diameter, or did you upsize any of the exhaust components?
Old Jun 22, 2018 | 03:38 PM
brian42's Avatar
brian42
Veteran: Navy
Forgot to mention that mine has a muffler. It is basically a straight pipe (4" opening down the center) with some baffles around the circumfrence to provide some sound-deadening. The baffles are beveled for directional attenuation with an arrow on the outside of the muffler. Install the muffler with the arrow pointed towards the rear and the noise is mildly attenuated. Point the arrow towards the front of the truck and the noise has "maximum" attenuation.
I have it pointed to the rear and the noise isn't too bad. I'm not a full throttle kind of guy so the noise is moderate. I live in a large neighborhood and, as Mike321 mentioned, I drive like I live there and have never received a complaint or comment on the noise.
Old Jun 22, 2018 | 04:44 PM
dieseldogtom's Avatar
dieseldogtom
7.3 Van guy here. And the type of guy that likes doing stuff like removing mufflers.
Thought it was going to make a difference in the ability of the diesel to "breath" better.
And (thought) that it would sound cool to be able to hear the turbo spool up...
My advice, DON'T waste your time to remove it. More than likely you will wish
you could get it back to the quiet sound it was before. NO NOTICEABLE DIFFERENCE
IN POWER OR ANYTHING ELSE except being louder. And it's makes an open invitation
to any cop to pull you over and give you some crap and look you over for anything to generate revenue
for the local municipality. JMHO. DDT
Old Jun 22, 2018 | 04:54 PM
DieselDenny
Running stock pipes, No rumble. Just a mild flowing reverb. Not annoying inside or out.
Denny
Old Jun 24, 2018 | 09:45 AM
HD Rider's Avatar
HD Rider
I had 5" straight pipe for about 6 years. At first I thought it sounded okay. It was a little loud towing. Towing on a long trip, it was just plain annoying. I put a Walker big truck muffler on and I can tell you that it's much more pleasant to drive on long trips even when not towing. I'll never go back to a straight pipe.
Old Jun 25, 2018 | 12:11 AM
'88 E-350's Avatar
'88 E-350
When I finally found the local straight pipe guy at a gas station he said the same thing. None of the hundreds of people he drove past every single day ever said a word.....because it's impossible to unless you track the offender down. All the other neighbors around me talked about him and how obnoxious his truck was. If you're out in the boonies it might not be a big deal. If you live/drive in the city you are absolutely that guy that most people wish would go away.
