1950's Ford
Old Jun 21, 2018 | 10:18 AM
BenJack9903's Avatar
BenJack9903
1950's Ford
Hello. I'm considering purchasing a 1950's model Toro Golf Course Tractor. It has a Ford, flat head 6 cylinder engine and a ford rear end, with a 4 speed transmission. Any insight on identifying the motor, rear end, and transmission (numbers, id plates, etc.) and possible sources for parts?
Old Jun 21, 2018 | 11:41 AM
jmadsen's Avatar
jmadsen
Probably an H or G series 6 cylinder.
on top of the head towards the front look for casting # 7HA. The distributor would be on the drivers side of block. G series would have distributor on the front of the engine.
Trans case passenger side a couple inches down from top will have casting # maybe 59t or ??
the 4 speed non synchro trans.
Post up some pictures of what youve got and we can help identify.
Josh
Old Jun 21, 2018 | 12:11 PM
Mixer man's Avatar
Mixer man
In the unlikely event it has the Big Six engine, it will have casting number 8MTH on the cylinder head. Pictures would be a great help.
Old Jun 21, 2018 | 12:18 PM
BenJack9903
I don't have a lot of photos since I haven't bought it yet. I'm trying to see what I'm getting into. I appreciate the help.
Old Jun 21, 2018 | 12:22 PM
56panelford's Avatar
56panelford
That doesn't look like any flat head motors I've seen, that's an overhead engine 215 likely
Old Jun 21, 2018 | 12:27 PM
BenJack9903
Any ideas how to confirm that or where to get parts?
Old Jun 21, 2018 | 12:32 PM
Hotrod350's Avatar
Hotrod350
That looks like my engine. I think it is a 223 OHV. In a 215 the distributor, oil filter, and coil are further back.
56panelford
It's an overhead because there is a valve cover, I'm not up on my engines but believe because the distributor is more forward it is a 215 cu in. There should be casting numbers on the block and someone here will know for sure. Numberdummy (Bill) is one of the best sources. Give it a bit of time and you'll get your answer..
Old Jun 21, 2018 | 12:33 PM
56panelford
I thought the 223 had the distributor closer to the center of the block..guess I'm mistaken
Old Jun 21, 2018 | 01:12 PM
Mixer man's Avatar
Mixer man
Parts for the engine should not be a problem at all. What other parts might you need?
Old Jun 21, 2018 | 05:25 PM
52 Merc's Avatar
52 Merc
That must be a beast of a lawn mower. I'd like to see more of it.
Old Jun 22, 2018 | 10:08 AM
petemcl's Avatar
petemcl
Can't help much without some pictures.
Old Jun 22, 2018 | 10:19 AM
56panelford
Pics in post #3 Pete..
Old Jun 22, 2018 | 10:24 AM
petemcl's Avatar
petemcl
Ooops, sorry. I missed those somehow.
Old Jun 22, 2018 | 10:32 AM
56panelford
Sometime they don't always show up for me until I refresh the page for some unknown reason...lol
