Idler Pulley
Old Jun 20, 2018 | 03:57 PM
JRT812's Avatar
JRT812
Idler Pulley
Where does this attach on a 78 f150 400? Appreciate the help.
Old Jun 20, 2018 | 04:04 PM
balexander's Avatar
balexander
Just tried to send you a picture of set up. Disregard that the compressor is aftermarket, the idler pulley is attached to the original compressor bracket.
Old Jun 20, 2018 | 04:05 PM
balexander's Avatar
balexander
Old Jun 20, 2018 | 04:37 PM
JRT812's Avatar
JRT812
Thanks! Preparing to do AC, but do I need that bracket as well? If I do, would you know where I may order one? Ordered a similar looking pulley and just prepping for the weekend.
Old Jun 20, 2018 | 04:43 PM
JRT812's Avatar
JRT812
For some reason I don’t have the pulley or that bracket
Old Jun 20, 2018 | 05:30 PM
balexander's Avatar
balexander
It bolts to the top of the compressor in those two holes. Also a bolt on the water pump or block. Can't remember. No one that I could find made it aftermarket. I put an ad on Craigslist and found someone locally who was parting a truck out and bought both brackets. Check e-bay or the junk yard, or do what I did and put a message out locally or on this forum. Good luck, you'll find one eventually!
Old Jun 20, 2018 | 05:59 PM
JRT812's Avatar
JRT812
Thanks my man!
Old Jun 20, 2018 | 08:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Which side do you need? The right side is adjustable and the left side is fixed.
These are the same as 1970/79 F100/350's, Passenger Cars, Econolines and 1978/79 Bronco's all with factory installed integral A/C & 302/351M/400/360/390.
Old Jun 25, 2018 | 02:43 AM
JRT812's Avatar
JRT812
thanks ND and apologize for the late response. It’s the adjustable side.
Old Jun 25, 2018 | 03:20 PM
NumberDummy
D8OZ-8678-A (replaced D0AZ-8678-C) .. Adjustable Idler Pulley-Use with factory installed integral A/C (Motorcraft YS-103) / Obsolete
Misc applications: 1970/79 F100 302 // 1973/76 F100/350 360/390 // 1973/79 F100/350 460 // 1977/79 F100/350 351M/400 /// 1970/71 Thunderbird 429.
1970/72 Mustang/Cougar 302/351C/351W // 1978/79 Bronco 351M/400 // 1978/79 LTD/LTD II/Ranchero/Thunderbird/Cougar/Granada/Monarch/Versailles 302/351W
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
MUSTANG SERVICE CENTER in North Hollywood CA has 1 = 818-765-9266.
MUSTANGS ETC. in Van Nuys CA has 2 = 818-787-7634.
D0AZ-8678-C =
NOS PARTS SOURCE has 1.
AAAA AUTOMOTIVE in Howe TX has 10 = 903-546-0024.
Old Jun 29, 2018 | 12:12 PM
JRT812's Avatar
JRT812
D0AZ-8678-C =
Thank you sir!
rechinca
28
Jan 1, 2017 05:54 PM
riverbedjedd
Jul 19, 2015 09:37 AM
graderman
May 7, 2009 06:59 PM
Jrock909
Apr 8, 2006 05:10 PM
acheers
Apr 29, 2003 12:06 AM
