303 relay clicks, no fuses blown, fuel pump works, fuel heater is unplugged I do not have power to fuel shut off switch. I have come to a lost on what else could be wrong.
Read voltage across the lead battery while cranking to verify you are not dropping below 10.5V.
Big time tip there. I chased a problem with my old f150. It was this. I had just enough voltage not running to make me look everywhere else. Still no crank.
When I figured this out I was dropping crank voltage way to low.
