quick question
Old Jun 19, 2018 | 09:00 PM
mojoman's Avatar
mojoman
quick question
got flooded this spring...both axles were semi submerged for 2 weeks...are the bearing sealed or do I need to replace/repack them????
thanks folks!!!
mojo
Old Jun 20, 2018 | 09:14 AM
farmert's Avatar
farmert
The axles do not use a sealed bearings in them. They use the cone and cup type with a seal on the outside of the hub. The front need to be packed with grease, the rears are lubed by the oil from the differential. If it sat for 2 weeks submerged, it would not hurt to pull the rear diff. cover and change the oil and repack the fronts.
Old Jun 20, 2018 | 09:26 AM
mojoman's Avatar
mojoman
thanks!!!!!!!
mojo
Old Jun 20, 2018 | 09:29 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
DO IT for sure. My F150 sat in SIX FEET of water for two weeks last August into September thanks to Hurricane Harvey. Water poured out of the rear axle...and the trans and the engine. You may want to run the fresh gear oil for a bit, then change it again in the event there is any residual water in the thing.
Old Jun 20, 2018 | 04:28 PM
mojoman's Avatar
mojoman
Cool
crap...just changed out the rear end fluid and gasket a yr ago...the water was at half axle height...thanks budz!!!!
mojo
Old Jun 20, 2018 | 04:49 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Just better safe than sorry. Gear oil is cheap so is a tube of RTV and a sixer.
Ryan Weaver
21
Dec 1, 2016 04:51 PM
Runningaddict
Dec 22, 2015 08:01 PM
61eline
Jul 1, 2012 05:14 PM
Big Rig
Aug 25, 2005 08:28 AM
Street
Dec 1, 2004 02:28 PM
