'48-'50 hood trim clips
A little more progress; Only three of the mounting clips for the side and front opening trim survived when I removed the trim from my hood. I never got around to ordering any and I was afraid I would scratch the paint on the hood or damage the trim installing them anyways. So, I made some stainless screws to mount the trim with. I just finished TIG welding them a few minutes ago. Now I can clean up the trim and get it installed. Here is a couple of photos.
Thanks, Mark
Thanks, Mark
Thanks guys for the replies and kind words. I installed the nose trim and hood latch this afternoon and the screws did make it easy to install the trim. I thought I had really messed up on the hood latch though. I screwed the latch stud in and left it long so I could see how much to adjust it. My latch stud has a little bend in it and I left it way too long and it went all the way through the latch plate and locked on the top edge of the plate. When I finally figured out what had happened, I padded a flat piece of steel bar and stuck it between the hood and grill top and pounded the latch stud over a little to unlock the hood. After I readjusted the stud, the hood latches and unlatches fine.
Thanks again, Mark
Thanks again, Mark
