Frekin DipStick Tube!!!!
Just got new motor in and running, take for test drive down highway and frekin dipstick tube fail to seal and blows oil out every where, pressure dropped down to 20lbs and I shut it down and found oil blown everywhere. Hopefully no damage done. So this is the oil pan I bought and put on. So assuming my engine isnt screwed can someone give me advice on dipstick tube options? I have looked some up but am struggling to understand how they can mount to my oil pan?
Ford Performance Parts Oil Pans M-6675-A460
https://www.summitracing.com/parts/fms-m-6675-a460
Yes and mine was attached, but where is attaches to the pan was just not a snug fit and oil would shoot out around it with high rpms
Well the oil system has pressure which going 65 down highway is 50lbs plus, mine has been showing upwards of 70lbs That alone will blow oil out somewhere if not sealed and since it mounts in the pan and not the timing cover makes it all the more easier to blow out.
So your saying that my oil pressure it to high? Even the motor I had in before this one had 80pis when cold and dropped down to around 50psi when warm?
At idle no oil comes out the oil pan dipstick tube hole, but when I rev engine oil starts shooting out the hole, I assumed this is normal if the hole isnt sealed properly. Am I looking at this incorrectly?
mine has 460 but cant imagin there is much difference. however attempting to modify the tube I broke the end off and now I was looking at aftermarts tubes but the dont appear to have mounting end like mine and I didnt know what kinda modification the pan required to use one.
Jpegg01,
I'm not familiar W/the 460 dipstick tube, so I'll do the best describing mine and what I did to get mine to get it from leaking on my 77 F-150 4x4 W/the 351M/400 engine. I had to remove the oil pan to get access to the dipstick tube fitting. The actual dipstick tube fitting was riveted to the side of the oil pan and is cast iron. Appeared my oil dipstick fitting was leaking due to the gasket between the oil pan and fitting was old, brittle and very thin, and had become loose over time. I cleaned the inside of the oil pan once I had it removed, ground off the rivet head and removed the rivets. I cleaned, the oil pan mounting surface with emery cloth, did the same with the cast iron dipstick tube fitting and used Permatex Right Stuff Gasket maker. I also got four stainless steel screws and nylon lock nuts; instead of re-using rivets. My dipstick tube has a brass fitting that tightens the tube onto the actual dipstick mount, that mounts onto the side of the oil pan. I used high pressure sealant on the threads of brass fitting and that was back in November of 2016 and it has not leaked since. I performed that repair during the rear main seal replacement, while I had the oil pan removed.
Don't be surprised if you have to remove your oil pan which you might have to jack your engine up to get clearance to remove your oil pan. Hope this helps.
