Aerostar Ford Aerostar
Wheel Spacers
Old 06-16-2018, 08:41 AM
Car Guy's Avatar
Car Guy
Car Guy is offline
Wheel Spacers
Does anybody know where I can find wheel spacers with a centerbore specific for the Aerostar? I’m running a set of non-Ford wheels and the offset is close but needs to be pushed out approximately 10mm. Any help with this would be much appreciated! Many spacers are available but I haven’t been able to locate anything with a specific centerbore. Hoping to find something with a better fit than the generic pieces you find at the local auto parts store.
Old 06-16-2018, 09:00 AM
RojoStar's Avatar
RojoStar
RojoStar is offline
eBay search using your bore size, 64.1mm
At that thickness (10mm) you'll likely end up with a shim style spacer, rather than adapter style, and then be needing an equivalent extension to your studs.
Old 06-16-2018, 12:31 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
I was concerned with the center bore of the Explorer wheels I got for my Aerostar; the Explorer wheels have slightly bigger bore, so they don't get hub-centered on the Aerostar hubs. But they were centered just fine by the lug nuts; they run very smoothly with no vibrations at all. So find yourself some beefy lug nuts. I got the stock Explorer lug nuts which held the wheels perfectly centered, and provided the attachment points for the stock hub caps:
https://photos.app.goo.gl/GbNRuVD7UyFADdKr8
I was concerned about the stud length. The aluminum wheel flange is a bit thicker than the stock steel wheels, so the studs didn't stick through as far. So when I tightened the nuts on them, they did not have as many threads showing as stock. I was thinking seriously about installing longer studs, especially if I experienced any wheel wobble on turns. But a year later while I was rotating the tires, I saw no distress on any of the studs or nuts, so I stayed with the originals.
Old 06-28-2018, 09:01 PM
Car Guy's Avatar
Car Guy
Car Guy is offline
I thought centerbore size was 70.6? With a 5mm shim I was thinking longer studs wouldn’t be neccesary
I’m not concerned with the wheels having a larger centerbore but want the spacer’s centerbore to be 64.1mm. This is why I posted a thread weeks back curious how thick the center section of a Aerostar brake rotor is. (I’ve yet to confirm this). My idea is to cut off (with a metal lathe) the surface where the lug holes/hub centerbore pass through. That becomes an exact fitting spacer. I did this on a ‘72 Chevelle I owned and the result was perfect.
Old 07-22-2018, 05:08 AM
Goethfather's Avatar
Goethfather
Goethfather is offline
i just bought these, and mounted them, works fine (Y)
https://www.ebay.com/itm/2-Pcs-Wheel...53.m2749.l2648
Old 07-22-2018, 04:16 PM
zenish's Avatar
zenish
zenish is offline
those are the wrong ones but close enough.aerostars are 115.
Old 07-22-2018, 11:21 PM
Goethfather
What do you Mean they Are 115?
Its 114.3 .
Old 07-24-2018, 04:31 PM
zenish's Avatar
zenish
zenish is offline
Its 114.3 .
you are right.i was confused.
Old 08-01-2018, 08:25 AM
Car Guy's Avatar
Car Guy
Car Guy is offline
After an hour of searching, I found ‘shim style’ spacers on Ebay. They are 5mm thick, hub-centric, and reasonably priced. They are on their way, we’ll see...
kennyfzj80
01-31-2018 06:33 PM
1984Fordf250
02-27-2014 10:34 PM
jimjudy2
1997 - 2003 F150
07-04-2008 05:21 PM
EZLariat
2004 - 2008 F150
07-16-2004 08:09 PM
natewoz
08-02-2003 09:50 PM
Quick Reply: Wheel Spacers
