05 F-150, 5.4 Lariat Bent Rod #1 cylinder.
Old 06-16-2018, 12:01 PM
gamboni's Avatar
gamboni
gamboni is offline
OK gotcha thank you. I’m still wrestling with the back bolt on the valve cover against the fire wall and the back bolts on the intake they are a bitch I need to remove this harness but I can’t get that to the harness bolt that you’re referring to.I just took off the right front tire and the wheel well shield maybe I can get that valve cover bolts off that way
Old 06-16-2018, 12:03 PM
gamboni's Avatar
gamboni
gamboni is offline
Looks like it’s attached to the starter I need to take those cables out
Old 06-16-2018, 04:22 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is online now
I know exactly what bolt you are talking about. I always leave those rear valve cover bolts out when I put it back together. Ford actually reduced the amount of bolts when they redesigned the heads in 2008 and left that bolt off. A 8mm swivel socket with a short extension will help get to it. I've never had to remove the starter cables to get the head off. I just lay the harness to the side.
Old 06-16-2018, 07:05 PM
Byoung Oh's Avatar
Byoung Oh
Byoung Oh is offline
Originally Posted by gamboni
Byoung_oh, no your engine sounds like mine did BEFORE the rod bent....Sounds normal to me. I did not take a video of mine run because I knew it was bad and did not want to run it anymore than I had to. Anyhow my connecting rod was hitting the bottom of the engine head and it sounds just like somebody is "pounding on a door" literally. You do not hear the metal cling like you think you would, it's a hard Knock and you will know right-away it's not good.
I was concerned about noise from the injectors. If I hear hard metal to metal knock, then probably too late.
I just didn't know if it would be a worth while to replace injectors before they fail.
Old 06-16-2018, 07:50 PM
gamboni's Avatar
gamboni
gamboni is offline
Hi If you have an 05 5.4L, I would change the injectors right away. You can get a whole set rebuilt on Ebay for $100 - $150. It's real easy to change. At least a whole easier then the mess I'm into.
Old 06-17-2018, 07:52 AM
gamboni's Avatar
gamboni
gamboni is offline
Good morning 70f100longbed, can you please tell me the secret to the AC lines quick disconnects to remove the accumulator? Is the insert for the clamp on the front or the back. I cannot get the tool to insert. It fits snug around the pipe. I am sure it is the right size.
Old 06-17-2018, 08:40 AM
70f100longbed
The tool inserts from the back, It helps to push the fitting together and twist it a little to break loose the o-rings. There is a circular spring that holds the fitting together and the tool spreads the spring. You should feel the tool slip by the spring. I hope you have had the system evacuated first.
Old 06-17-2018, 12:56 PM
gamboni's Avatar
gamboni
gamboni is offline
Yes, I got it off and yes I did evac first. OK, Round three. Please see pictures below. Did you remove the transmission dip stick. Not sure how this head is going to come off with the exhaust manifold on but I am not there yet anyways. Two questions please:
1. I have never taken a timing cover off a V8. Is it all one unit for both cylinder blocks or two seporate covers ? Do I need to remove the tension-er and Idler pulley on passenger side.
2. Is it necessary to take off the fan? I do not have a fan clutch and no car to get to the auto parts store.
Very hot in Chesapeake today. Somebody bring me some water!
Old 06-17-2018, 02:52 PM
70f100longbed
The trans dipstick can stay but there is a 18mm bolt holding it to the head. The timing cover is one piece so you need to pull the other valve cover to get it off. The fan needs to come off as do the water pump pulley. I would search youtube for timing cover removal.
Old 06-19-2018, 07:35 PM
gamboni's Avatar
gamboni
gamboni is offline
Hi 70f, the last thing I have before removing the timing chain cover is finish removing the intake manifold. I removed eight bolts see picture above. I am aware of the bolt in the back holding the harness.. I can't seem to pri-off the intake. Am i missing something?
Old 06-19-2018, 10:38 PM
70f100longbed
I usually pull the alternator and water outlet/thermostat housing just to get them out of the way. I can't remember how many bolts there are on the the intake but 8 sounds low to me. There are probably 2 more hiding somewhere. I admire you taking on such a huge job.
Old 06-20-2018, 10:38 AM
gamboni's Avatar
gamboni
gamboni is offline
Thank you, I am kinda admiring myself for taking on such a big job. I hope it works otherwise I will have been very foolish. But I had to try because my pride told me to fix it since I broke it. I love my truck, it has been very good up to this point. I watched all 4 of the "Maculoco" timing chain replacement series..they are really good. Is it really that difficult to remove the chain? Do I have to do all that to remove the head? I feel like when i remove the head the whole thing is going to fall apart like a Jenga pile.
  #28
Old 06-21-2018, 02:44 PM
70f100longbed
Yes there is a lot that has to come off. You are basically taking the engine down to almost a short block.
  #29
Old 06-22-2018, 01:14 PM
gamboni's Avatar
gamboni
gamboni is offline
It would have been easier to replace the engine,. I am on my last bolt (the exhaust manifold). figures the bolt is stripped. By any chance are you available for telephone support tomorrow when I pull the timing chain off. I would be happy to pay whatever your hourly fee is via Paypal. I am afraid I am going to do something and not know hoe to get it back right. Please let me know my number is 7578103824.
Dale Gamboni
  #30
Old 06-22-2018, 03:39 PM
70f100longbed
But replacing the rod is much more fun!! I'm not available tomorrow but I described how to set the cams and crank to take the chain off in post #15. Are you replacing the phasers too?
Quick Reply: 05 F-150, 5.4 Lariat Bent Rod #1 cylinder.
