Insert Synchronizer
Old Jun 13, 2018 | 03:17 PM
Smax39's Avatar
Smax39
Question Insert Synchronizer
Hello, i have a F3 1951 with V8 Flathead and manual 3 speed transmission and i would like to know if this possible to insert a synchronizer in a gearbox without synchronizer. Thanks for your time. Maxime
Old Jun 13, 2018 | 04:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Welcome to the forum!
Your truck should already have synchronized 2nd and 3rd gears. If it feels like they aren't working, perhaps the brass blocking rings in the synchros are worn out, or maybe your clutch isn't adjusted correctly and is dragging. But you can't add synchromesh to gears that don't already have them. Have you also checked the oil level in the trans?
Old Jun 14, 2018 | 01:39 AM
Smax39's Avatar
Smax39
Thank you for informations. I have look in Web, for light duty 3speed synchronizer and for Heavy Duty 3speed no synchronizer same truck military. I must change clutch yes.
Old Jun 14, 2018 | 09:48 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Show us what you've got and explain what you are trying to do. I understand there may be a language problem to work around. Is your truck one made for the French military? The best source for transmission parts for our trucks is Van Pelt Sales, VANPELT SALES LLC - your ford flathead source since 2006.
US trucks did not have a 3-sp without synchronizers, only a 4-sp, and they were very common in F-3's.
Old Jun 14, 2018 | 11:37 AM
Smax39's Avatar
Smax39
The person who had made him imported told me that it was necessary to use the technique of the double clutch to cross speeds. Thus I thought that there was no synchronizer otherwise speeds would pass as on my recent car. But i have F3 stock with V8 Flathead. Sorry i m novice.
Old Jun 14, 2018 | 11:40 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I think you have the non-synchro 4-speed. 1st gear is so low that it is not used except when starting with a heavy load. Check your shift pattern! Is there a metal serial number plate on the inside of the glovebox? Take a picture of that and post it here (take a pic of the truck, too!).
Old Jun 14, 2018 | 11:57 AM
Smax39's Avatar
Smax39
yes 1st low but no so low, i have 3speed, i have check with gear lever.
Old Jun 14, 2018 | 12:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Either you have a transmission different than those offered in the rest of the world, or you have a 4-speed that is just not willing to go into 3rd. It should be like this:
Old Jun 14, 2018 | 01:19 PM
Smax39's Avatar
Smax39
oh my god, really? 4speed? on web (wiki) just 3speed. Okay i look at this. 4speed no synchro. thanks so much for your help.
Old Jun 14, 2018 | 11:30 PM
ben73058's Avatar
ben73058
Bienvenue Smax. Show us some pictures of your truck when you get a chance.
It would be nice to see what a French version of our trucks looks like..
Ben in Austin
1950 F1
Old Jun 15, 2018 | 01:22 AM
Smax39's Avatar
Smax39
Hello Ben,
i m sorry but my truck is imported of US. It’s 100% USA i like it <3. But the old owner he explained to me. It’s F3 with 3speed no synchro and V8 Flathead. Yes i have Flathead but no 3speed but 4speed... i think change for C4 automatic...
Old Jun 15, 2018 | 11:29 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Very nice looking truck! Amazing condition.
Can you take a picture of the transmission, particularly on the passenger side? If there is a plate on the side of the trans, held on by 4 or 6 bolts, that will confirm the 4-sp.
Old Jun 15, 2018 | 02:45 PM
Smax39's Avatar
Smax39
sorry I'm not going to my truck for a while but my father is going to look at the transmission to find out what's written. otherwise I would look for the passenger side. thank you yes I am lucky he is in great condition. just a few things but nothing serious.
Old Jun 15, 2018 | 03:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
By the way, your serial number indicates your truck is indeed a 1951 F-3 made in the Kansas City plant.
Old Jun 15, 2018 | 04:36 PM
Smax39's Avatar
Smax39
Yess thanks so much for this informations. I say also it belonged to Mr. Joe cobb to Damascus,Oregon. I like history for my truck.
