1975 Crew Cab
Old Jun 11, 2018 | 12:29 PM
75kona's Avatar
75kona
1975 Crew Cab
Went looked at this truck yesterday. It was a little more rough than I originally thought. On the passenger side it has a cab corner gone poorly repaired along with the space in-between the doors which I though was an odd spot for rust. It has a 460 and an automatic that run rather well. It is advertised as a F250 but I has 5 lug wheels. I thought that meant it was a F150? Needs a lot but I runs and drives right now. He is asking $7500. Thoughts?
Old Jun 11, 2018 | 05:15 PM
colonelmustard's Avatar
colonelmustard
Run the info on the warranty plate on the lower portion of the drivers door jamb. That will tell you how the cab left the factory. Also check the vin# stamped on the top of the frame near the alternator and match it to the vin# on the warranty plate. Cab may have been moved to another chassis. Or other possibilities! 460's did not come in 4x4 Dentsides from the factory.
Old Jun 11, 2018 | 05:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No such thing as a 1973/79 F100 or 1975/79 F150 Crew Cab, all are F250/350's and all were assembled in Oakville Ontario Canada.
Only F100/150's and Bronco's have 5 lug wheels, so something smells and it ain't hay!
No 460's with M/T & 4WD until 1983.
Originally Posted by colonelmustard
Run the info on the Warranty Plate on the lower portion of the drivers door jamb (plate riveted to the left door face below the latch). That will tell you how the cab left the factory.
No code within the VIN decodes to Crew Cab, neither does the MODEL aka TYPE/GVW code stamped on the Warranty Plate.
If the 3rd digit of the BODY code stamped on the Warranty Plate is D or G = Crew Cab. D is a Crew Cab pickup, G is a Crew Cab Chassis & Cab.
Old Jun 11, 2018 | 05:50 PM
colonelmustard
Definitely a Frankenstein of some sort.
Old Jun 11, 2018 | 06:24 PM
1320stang's Avatar
1320stang
It appears to have OBS mirror brackets, notice how they go downhill towards the cab.
Old Jun 11, 2018 | 06:34 PM
NumberDummy
Mirrors are 'el cheapo' auto parts store replacements.
Genuine Ford TYPE 9 mirrors are "swing locks."
Notice in the pic that the round 'swing-lock' disc isn't located between the upper bracket and the arm like it is in the parts catalog pic.
Old Jun 11, 2018 | 11:44 PM
highoctane74's Avatar
highoctane74
Good eye! I just learned something new!
Old Jun 12, 2018 | 10:42 AM
75kona's Avatar
75kona
Thank you guys! This is exactly why I come here. I will be avoiding this truck.
Old Jun 12, 2018 | 12:33 PM
somethingclever's Avatar
somethingclever
looks like an F150 supercab 155" WB frame with a crew cab body.
John Joesph Aguilar
Projects
Sep 4, 2018 12:22 AM
46Whizzer
15
May 6, 2018 08:35 AM
78F-250Lariat
Feb 21, 2018 09:25 PM
GranddaddysTruckGirl
Aug 29, 2016 03:57 PM
Rbeck204
Nov 26, 2015 02:39 AM
