Thinking about buying a 79 Ford dump truck, trying to figure out what engine it has in it. Present owner has VIN but the door tag is missing. VIN is F82BVDC5899 . Any info appreciated. Thanks in advance.
F82 = F800 (gas) / B = 300 1V I-6 or 370 4V V8 / V = Kentucky Truck Assembly Plant / DC5899 = 1979.
Also see your post in the "If you need any info" thread for GVWR info.
Thank you very much sir. The plate on the do or is missing and I don't know if there is still anything on the b piller as it looks like it was painted.
The VIN series code is F82.
Pic: If the Warranty Plate was present, the TYPE/GVW aka MODEL code and its corresponding GVWR (Gross Vehicle Weight Rating) would be one of the following:
