78 b600 361swap to 429?
Ive got a 78 b600 bus with a 361 and allison allison at540 auto trans, i cant pull a hill over 20 mph, it takes forever to get up to 45mph on flat ground, i cant believe that this is all this turd has got in it! The motor runs good, no smoke or knocking. Im thinking of putting the 429cj from my 3/4ton 4x4 in the bus so it will have more grunt. What will i need to do to put the 429 in place of the 361, or does anybody have any suggestions as to what is keeping my bus from pulling its own weight?
Ive taken the cap off the distributor and the advance weights move against the springs, vacuum advance seems to be working as it changes idle when i unplug it from vacuum. Points look newish and gap ok...starts just fine runs good, maybe a pop or two when going down a hill and my foot is off the acccelerator, no smoke or engine knock or ping under load. My vacuum gauge plugged onto the manifold vacuum tree reads "late valve timing/intake manifold leak" but ive checked all my vacuum lines, tightened all clamps, made sure carb is sealed, and sprayed all over the intake w carb cleaner and cant seem to find any leaks. Maybe my timing chain has stretched that its making my valve timing that far off? Im not new to ford v8s or anything else with an engine, but this has me stumped. Im going to pull a compression test today to get solid numbers for each cylinder, but ive usually seen smoke or had another sign of a worn out motor if the compression was low enough to make it as gutless as this is.
I'm not sure how much help I can offer, but here's my two cents worth. I've remembered vividly riding in many buses powered by gas engines as a kid. Even had the pleasure of driving a couple of those buses, one a B600 powered by a 361 with a 5 speed (1st was never used to start off). I've even driven a B600 powered by a 361 with an Allison once, and I remembered its top speed was about 45 mph on flat ground. So, going no more than 20 mph climbing up a hill would sound about right. That said, you can tweak around as much as you can with the timing and carb settings all you want but you're likely wasting a lot of time for very little to no reward.
As far as you're intent on an engine swap goes? A 429 V8 is part of Ford's "385" Series V8 engine family if I'm not mistaken. This would be the 370/429/460 family of engines. That said, the bellhousing bolt pattern on your 429 V8 is different from the 361 V8, which I believe is what Ford called their "FT" engine from the 330/361/391 lineup. For lack of a better way of describing it, the "FT" have a much more circular type of pattern compared to that of your 429. I'm not sure as to why you're not worried about engine mounting because if your 429 is coming from a light duty truck, it will be mounted by the left and right sides of the block whereas your 361 is supported at the front of the engine along with the left and right sides of the transmission bellhousing.
Now, Ford did begin using the 370 and 429 engines from 1979 onward, but on those applications I believe the engine was also supported from the front on medium duty truck applications, so I'm not sure if the engine front covers will be medium duty truck application specific (different from the 460 which was used only on passenger cars and light trucks). Your bellhousing issue will likely be your biggest hurdle.
EDIT:85e150six4mtod beat me to the punch!
You shouldn't have vacuum on the vacuum advance. If the vacuum advance dashpot dual-ported or single? And if it's single, it's sticking out towards the front of the vehicle? Where does the vacuum advance line connect to on the carb? Can you post pics?
Vacuum on these should be "ported" vacuum - they should only have vacuum as you step on the gas, not at idle.
If you're using manifold vacuum for vacuum advance, the advance will RETARD as you get into the go-pedal and the engine won't accelerate correctly.
Ok, so ive just finished compression test...holes 1-4 are 115,115,105,110. Holes 5-8 are 105,105,120,105. Number 3 plug didnt appear that it had been seated fully, it had a bunch of carbon build up around the base of the plug and it only took a couple turns to get it out. Plug number6 was finger "tight" and wiggled when i pulled the plug wire off. Plugs 7 & 8 were tight, but with a thin smooth black covering everything in the combustion chamber like not firing while all 6 other plugs looked nearly new with no appreciable deposits or discoloration.
Put new plugs in it, make sure they are in there, and run it for a hundred miles. Pull and recheck. That "smooth black coloring" is the cylinder is rich (soot). I wouldn't jump on an intake leak right away without further diagnosing the issue. Why 7 and 8 would be rich, and the others normal-to-lean, makes me wonder if there really is an intake leak, but I'd run it a bit to make sure.
