Original Engine to frame ground location?
What does the original ground strap look like? Cable, braided strap, etc...
I am sure the Abe can give you the answer right off the top of his head...I am more a functional guy and would put multiple ground straps in just to make sure that all bases are covered. Nothing more bothersome than a poor ground.
Charlie..... Thanks. Here it is off the top of my head. There is a braided strap from the driver's side head to the firewall near the accelerator linkage bolt. I have pictures but they are on the computer and the wife is on that now. I'm using my tablet. I don't think there is an engine to frame ground.
Thanks, that makes since, and would sure work. I just bugs me that my memory fails me I do like picture, so if it is ever convenient throw one on here.
Yep, as you can see they are in bad shape. If you get a chance that would be great. I think that little one on top that you shared, is to ground the cab only. Otherwise the cab would have no good grounding since it sits on only 4 rubber cab mounts.
I don't seem to have a good picture of my starter and how it is hooked up. To get new cables, I went to a local big truck shop and they made some out of 00 gauge while I waited. Here are two of the four.
I just took my old ones in and they made new ones to match the length. My battery cables were really small, someone just used 12v cables for that at one point.
I have bought a cable for cab to frame ground, but I have not installed it. Anyone know of a good place to hook that up?
