2003 expedition
Old Jun 8, 2018 | 01:51 PM
Bjokich's Avatar
Bjokich
2003 expedition
Not a new topic but how do I fix my 2003 Expedition with a PCM relay problem. The fuse keeps blowing out, even with a new fuse box. What is the next step?
Old Jun 8, 2018 | 06:28 PM
Hamfisted's Avatar
Hamfisted
How quickly is it blowing the fuse ? The fuel pump only runs for a few seconds when you turn the key to RUN. It runs steady once the motor is running. Is it blowing when you just turn the key to RUN ? If there's no shorts in the fuel pump circuit wiring, I would suspect the fuel pump itself. You can get one of those mini-fuse amp draw testers to determine the amps being pulled by the fuel pump.
Fuse Buddy Amp Tester on Amazon Fuse Buddy Amp Tester on Amazon
Old Jun 8, 2018 | 06:44 PM
Bjokich's Avatar
Bjokich
The fuse melted on our way to Fl. From Atlanta and we replaced the new fuse and it was fine for 5 days but did the same thing on the way home. We replaced the fuse box and the battery light is still coming on saying to check the charging system but it has not died again.
Old Jun 8, 2018 | 08:37 PM
Hamfisted's Avatar
Hamfisted
Sounds like two separate issues. With the engine running, what is the voltage across the battery ? Should be 14 volts or so. Is it the original alternator in the Expy?
I would still check the amp draw of the fuel pump for the fuse blowing issue.
Old Jun 9, 2018 | 06:18 AM
projectSHO89's Avatar
projectSHO89
It would help if you identified the specific fuse that is blowing.
rmh1999
Jun 2, 2023 11:40 PM
bucks77ford
General Automotive Discussion
Apr 17, 2011 12:12 AM
Bin Strokin
13
Jun 12, 2009 04:16 PM
Shane269
Aerostar
Apr 16, 2005 02:07 AM
skohler
Mar 4, 2005 09:18 AM
