points ignition retro
Old Jun 4, 2018 | 10:26 AM
LarsTurner's Avatar
LarsTurner
I have a 1986 f150, 300 engine, standard transmission that I am converting to non-feedback system. All emissions and computer are gone. I want to put a 71 points distributor in it. Pictures on line of 71 and 86 distributor look different. Will a 71 distributor fit in an 86?
Old Jun 4, 2018 | 12:42 PM
Franklin2's Avatar
Franklin2
They claim the dist in this link fits 1965 through 1986, so they all should be the same.
https://www.ebay.com/i/191838774982?chn=ps
Old Jun 4, 2018 | 04:17 PM
FuzzFace2's Avatar
FuzzFace2
First I have to ask why go back that old to points?
If you look up a picture of 80/81 dist. it will look close to the 71 as it will have vacuum advance that yours dose not have but it will be electronic so no need to replaced worn out points or need to set the dwell when the plastic rub block wears down.
A little wiring and the IGN box and you are good to go and never have to touch it again.
I am not a fan of them but that would be the HEI type of dist.
No need for the IGN box as it is built inside like your dist. now, but it has vacuum advance and no computer needed to work.
The hardest part is it will need a full 12 volts but that is it to work.
I would look into the HEI type. (edit: I see Franklin posted a link to one)
Dave ----
Old Jun 4, 2018 | 04:24 PM
matthewq4b's Avatar
matthewq4b
The Answer to the question is yes it fits. All 300 I6 Distributors will interchange (Physically bolt in) .
As for why.
It gives you the option of running electronic or points, Not some thing you can do with HEI or the Dura Spark Dist's
Old Jun 4, 2018 | 05:34 PM
Old Hickory's Avatar
Old Hickory
You can run an MSD box with points and the points just become a trigger for the box so
they never really wear out. I run this system on a 60s muscle car and haven't had to do anything to the points
in over 10 years.
Old Jun 4, 2018 | 06:47 PM
FuzzFace2's Avatar
FuzzFace2
in over 10 years.
If you put miles on it the plastic rub block will wear down changing dwell and that changes timing.
So you may not have power going thru them to make them pit they still wear.
What is nice unless the plastic rub block breaks they will never leave you stuck some place like a bad IGN box will.
If I had a points dist. I would install a point eliminate kit.
Dave - - - -
Old Jun 4, 2018 | 08:37 PM
matthewq4b's Avatar
matthewq4b
Dave - - - -
Can;t say I have ever seen the rub block arm break on a set of points. Mind you I can see that happening on some these cheap ones with plastic arms. I have always used all steel with a phenolic rub block. The contacts will go before the rub block will wears down at all after it is seated. It's like any thing buy on the cheap ones and you're gonna have issues.
Old Jun 4, 2018 | 09:02 PM
Rusty_S's Avatar
Rusty_S
Dave - - - -
Yep, that's why I eliminated that problem by doing a Petronix points elimination on my 58 Ford 641 tractor never had a problem again. Going to do the same thing on my 292 later on.
Old Jun 5, 2018 | 05:10 AM
FuzzFace2's Avatar
FuzzFace2
Back in the day, 70's, I seen one or two broken.
Now days can you even find points LOL
Dave - - - -
Old Jun 5, 2018 | 09:26 AM
LarsTurner's Avatar
LarsTurner
Thanks Franklin 2, but the distributor on that link is an HEI. I'm looking for old-school points.
Old Jun 5, 2018 | 09:31 AM
LarsTurner's Avatar
LarsTurner
I'm an old-school kind of guy, fuzzface2. I like the simplicity of the old points ignition, plus the look of the smaller distributor cab. I understand that points require regular fiddling, but I don't mind that.
Old Jun 5, 2018 | 09:33 AM
LarsTurner's Avatar
LarsTurner
Thanks, matthewq4b.
Old Jun 5, 2018 | 09:37 AM
LarsTurner's Avatar
LarsTurner
I'm looking for the cleanest possible look under the hood, so if I can avoid another gadget that what I want. Also, I like the look of the smaller old points distributor caps. My concern is whether or not the cam gear will align with the distributor gear. Also, I'm concerned about hindering oil flow if machining of distributor shaft should block off an oil passage.
Old Jun 5, 2018 | 09:40 AM
LarsTurner's Avatar
LarsTurner
I've seen plenty of places that sell points on other such parts for the older trucks, so I'm not worried about that.
Old Jun 5, 2018 | 09:46 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
The old cap will fit the Duraspark distributor. There will be absolutely no mechanical reason why the distributor would not interchange, no machining required.
It would be pretty difficult to pick up the visual difference between a 71 distributor and a Duraspark with the older cap. I am noting that the visual appearance appears to be more of a factor than reliability and performance, but the wiring associated with a Duraspark system is quite simple and it would be easy to arrange it in such a way that a clean look can be obtained.
I too wonder about the availability of points and old school caps vs. the Duraspark parts?
