1978 Lincoln heads
Old Sep 20, 2003 | 10:23 AM
Charlie torino's Avatar
Charlie torino
Angry 1978 Lincoln heads
I have a 78 Lincoln 460 motor with stock heads.Would it be o. k. to use these heads ,or better to use c8 c9 or dove heads. Thanks
Old Sep 21, 2003 | 12:43 AM
LxMan1's Avatar
LxMan1
1978 Lincoln heads
They will work fine. The older heads will give you more compression, but they use a different rockerarm set-up and require different pushrods.
Your engine should be about 8.0to1 compression. With the older heads it will be around 9.3to1 or so.
I use the stock heads on my 77(D3VE) and they should be the same as yours.
Jimmy
Old Sep 21, 2003 | 08:18 AM
Charlie torino
1978 Lincoln heads
Thank's for the help!
