E4OD troubles
Old Sep 20, 2003 | 01:55 AM
pfogle's Avatar
pfogle
E4OD troubles
I've been having an intermittent soft shift problem that is gettin worse. I can't even tell when it kicks out of OD anymore. I need to know if this is a transmission that I could rebuild my self with a good manual or if I should send it out. It may be a bad sensor as some days it shifts hard, and others really soft. It also seems to work better when the conditions are cool and not humid. Any and all help is much appreciated.
Old Sep 20, 2003 | 05:19 AM
1cpatrick's Avatar
1cpatrick
E4OD troubles
e40d trannys have a small plastic gear that activate the speed sensor. its located at the end of the speedometer cable, where the cable goes into the trans. mine is near the rear, on the drivers side, almost at the top. its a poor design cosidering the rpms generated, and the aftermarket parts are no better. try this maintainence before you go wild on that tranny. they are real expensive. good luck
Old Sep 20, 2003 | 10:54 AM
jimandmandy's Avatar
jimandmandy
E4OD troubles
'92 and later trucks do not use a spedometer gear/cable arragnement. They are all electronic. So that cant be the problem.
Hard or soft shifts are most likely caused by high or low oil pressure, which is controlled by the computer. Get the computer codes scanned before you do anything else.
Jim
Old Sep 20, 2003 | 01:53 PM
pfogle's Avatar
pfogle
E4OD troubles
Only code in the computer is the recurring AIR system, code that I just haven't cured yet.
Old Sep 21, 2003 | 05:29 AM
1cpatrick's Avatar
1cpatrick
E4OD troubles
sorry, didnt see that you had a 92. i better read more, type less
Old Sep 21, 2003 | 01:33 PM
thpnalb's Avatar
thpnalb
E4OD troubles
I'd look into the AIR and engine condition first, as the computer depends on readings overall to control the demands of the tranny. It sounds like a sensor problem being intermittent.
