4" down pipe?
Old 05-19-2018, 04:15 PM
Amicus's Avatar
Amicus
Amicus is offline
4" down pipe?
just in stalled a 4" down pipe. It is louder for sure. Also I seem to have some vibration some where. The bend behind the turbo is up against the fire wall. I don't think I can do anything about that? Just wanted to see if anyone had some advice or ideas about the vibration or anything else. Also there is a tranny pipe that runs right next to the down pipe. Do I need to try and move?
Thanks
Old 05-19-2018, 10:11 PM
mattdoc88's Avatar
mattdoc88
mattdoc88 is offline
This won't really help you but might help others. The general consensus is to get a 3.5" downpipe for these trucks because of the issues you're having. Then a 4" exhaust from the downpipe back fits ok. But due to the issues you're having, a 4" downpipe isn't great. You'll have to decide if you want to change to a 3.5 or fix your issues.
Old 05-19-2018, 11:51 PM
FiznUKa's Avatar
FiznUKa
FiznUKa is offline
Loosen the clamp on the turbo and rotate the down pipe until you find the sweet spot then tighten the clamp. I have a 4” turbo back and haven’t had any clearance issues. It’s close to the uppipes but it will fit. What brand did you purchase? That could also be an issue.
Old 05-20-2018, 06:48 AM
tfunk88's Avatar
tfunk88
tfunk88 is offline
Which brand do you have? I’m interested in getting a 4” downpipe
Old 05-20-2018, 07:43 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Received 3,392 Likes on 2,089 Posts
On the down side.... the 4 inch offers no benefit, the 3.5 helps with back pressure on the turbo which is necessary and performs better. Stock is 3 inch with a resonator for my 2003. If you want the 4 inch down to fit, you may have to hammer back the pinch welds on the cab to keep it from rubbing.
Old 05-20-2018, 07:49 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
FWIW--I've never had EGT or spool issues with my 3.5" downpipe. I got it because Magnaflow testing way back in the day found there was no benefit (actually less) using a 4" downpipe. The fitment issues are obvious.
Old 05-20-2018, 07:50 AM
tfunk88's Avatar
tfunk88
tfunk88 is offline
So should we go with a 2” downpipe to get more of that turbo performance enhancing back pressure?
Old 05-20-2018, 07:57 AM
npccpartsman
Seriously, you're going there?
Old 05-20-2018, 08:02 AM
tfunk88's Avatar
tfunk88
tfunk88 is offline
I’m simply asking a question.
Do you ha e a link to the Magnaflow testing? I’d be interested in reading it.
Old 05-20-2018, 08:03 AM
Maxium4x4's Avatar
Maxium4x4
I wouldn't but it is your engine.
As an owner you can choose what to do. Introduced in the year of 2003 and the DYNO time I an others have spent since then, my advice is pretty solid but ultimately it is up to you to decide what is right. To clear a 4 inch down you will have to adjust, make room, and live with rubbing if not done correctly. if you are planning on compound turbo's and aiming at 1000+ HP then the 3.5 down may not apply.
I and other members only offer advice, the final out come is in your hands.
Old 05-20-2018, 08:07 AM
tfunk88's Avatar
tfunk88
tfunk88 is offline
On the dyno the 3.5” pipe outperformed the 4”? That’s definitely interesting. And no, I’m not being sarcastic.
Old 05-20-2018, 08:12 AM
FiznUKa's Avatar
FiznUKa
FiznUKa is offline
Back to the subject on hand another option would be to mark the pipe with it installed and pull it back out and flatten it with a hammer wherever needed.
Old 05-20-2018, 08:13 AM
Maxium4x4's Avatar
Maxium4x4
We did hours of testing, you have trade offs for each system. 4" is not wrong or right but to answer, the VGT performs better with back pressure.
Old 05-20-2018, 08:20 AM
Maxium4x4's Avatar
Maxium4x4
Every truck model year is just a tweak different on clearance, I would not recommend hammering the pipe into submission. Just massage the cab area where you find the pipe rubbing.
Old 05-20-2018, 09:25 AM
AGE mechanic's Avatar
AGE mechanic
AGE mechanic is offline
Im not sure how back pressure would have any bearing on the VGT operation? I have had 4" AFE turbo back exhaust for many years now. My truck runs great. I pull a heavy Toyhauler without issue. I think the larger down-pipe is an excellent mod.
As stated earlier, just loosen the clamp and re-position. Also, keep the tranny lines from touching it.
Quick Reply: 4" down pipe?
