Urgent Brake Problem
Old Sep 19, 2003 | 07:22 PM
F0rdF0rever's Avatar
F0rdF0rever
I was replacing my brake pads. Everything was going normal until we started it up. No preasure, cant figure it out. We bled all the lines and still no preasure.
Old Sep 19, 2003 | 08:01 PM
believer45's Avatar
believer45
When you did the replacement did you push the "puck" back into the caliper to get room to get the new pads in? Sounds like you may just need to pump the brakes several times to get the new pads in position right at the rotors.
Try it and let us know.
I will check back in a bit.
Dave / Believer45
Old Sep 19, 2003 | 08:14 PM
F0rdF0rever
Thanks for replyingh Dave. Yes, we pumped them many times. And still little to no preasure.
Old Sep 19, 2003 | 08:20 PM
believer45's Avatar
believer45
When you say low pressure have you driven the truck to see how the brakes work or is there some other indicator of low caliper pressure?
Dave / Beliver45
Old Sep 19, 2003 | 08:22 PM
believer45's Avatar
believer45
You wouldn't happen to be anyhwere near Cincinnati, Ohio would you?
I am off tomorrow.
Dave / Believer45
Old Sep 19, 2003 | 10:44 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Is the pedal "spongy" like there is still air in the lines, or is there no assist at all?
Remember on the diesel's hydro-boost brake system, the pressure to operate the brakes comes from the power steering pump, so check the level in the P/S reservoir as well.
Old Sep 20, 2003 | 10:07 AM
F0rdF0rever
Thanks for all your help guys. I gave up on them late last night. This morning, I went outside started her up and the brakes work perfectly. I dont understand it, but they work..
