Sponsored by: Real Truck
master cylinder
Old May 22, 2018 | 02:02 PM
dublcluch's Avatar
dublcluch
master cylinder
any advise or tricks of the trade on replacing master cylinder on 2005 f250?
Old May 22, 2018 | 05:15 PM
redford's Avatar
redford
FTE Leadership Emeritus
Vacuum or hydroboost assist?
Old May 22, 2018 | 05:30 PM
Chuck's First Ford's Avatar
Chuck's First Ford
as Mr. Redford said...... nignt and day difference.......
also 2 or 4 wheel drive.... manual or automatic.. V8, V10, diesel ...??????. something.
Old May 22, 2018 | 10:28 PM
dublcluch's Avatar
dublcluch
haven't seen the vehicle yet, belongs to my son, ...how can u tell the difference?....thanks for any info...
Old May 22, 2018 | 10:37 PM
jetjockey99's Avatar
jetjockey99
Doesn't matter if it is hydro or vacuum boost. Just make sure that you bench bleed the replacement cylinder before installing it. When you actually do the replacement try to be somewhat speedy about it to avoid getting air into the ABS system and bleed at the master first and then at the wheels. If you do get air in the ABS module you will need to have someone with a high end scan tool like a Ford IDS do a service bleed to get all the air out.
DougieWebb
Feb 23, 2020 03:37 PM
Tim Hodgson
1978 - 1996 Big Bronco
Jan 29, 2019 10:18 PM
dogg16
Bronco II
Sep 14, 2004 04:19 PM
