clear liquid?
Old Sep 19, 2003 | 05:29 PM
F0rdF0rever's Avatar
F0rdF0rever
clear liquid?
Alright, another problem here. There is a liquid leaking, very slowly, from the ujoint area where the passenger side front wheel meets the axle. I have no idea what it is, almost smells like brake fluid. But doesnt look like it. Any ideas on what it is and how it can be fixed.
Thanks again..
One more thing. I plan on getting four new tires real soon for my psd. The ones on there now are in pretty tough shape. What does everyone prefer?
Old Sep 19, 2003 | 05:44 PM
RRMike's Avatar
RRMike
clear liquid?
Sounds like brake fluid to me. It's clear. There should be nothing else there in the way of liquids.
Old Sep 19, 2003 | 06:05 PM
Go Aweigh2452's Avatar
Go Aweigh2452
clear liquid?
As far as tires, you will probably get as many answers as there are replies... Looks like most are into Michelins and away from Firestones... I'll be using Mich's when the time comes... probably a higher ply too. A friend of mine uses 14 ply. yeap I said 14...
Old Sep 19, 2003 | 07:23 PM
F0rdF0rever
clear liquid?
But would brake fluid be coming from the ujoint area, its clearing not coming from anywhere else.
Old Sep 20, 2003 | 08:37 AM
mueckster's Avatar
mueckster
clear liquid?
If the fluid is coming from the axle tube behind the axle u-joint, then the axle seal is starting to leak. You should be able to see if a trail of oil is originating from inside the axle tube. If the seal is leaking and becomes bad enough, the carrier will have to be removed, as the seal is at the differential side of the axle tube. Is the diff oil level oil level over full or the vent line plugged? This could also cause the seal to leak.
Old Sep 20, 2003 | 10:10 AM
F0rdF0rever
clear liquid?
The fluid is coming from the axle tube behind the ujoint. How do I check the diff oil level? And if it is going is it expensive and/or difficult to do?
Old Sep 21, 2003 | 09:38 PM
mueckster's Avatar
mueckster
clear liquid?
Remove the plug in the front cover on the differential. The oil level should be to the bottom of hole. Check the vent hose on the top of the diff. It runs to frame on the driver's side. Make sure it is not plugged. It may stop leaking if the hose is plugged and you clean it.
Old Sep 21, 2003 | 09:46 PM
F0rdF0rever
clear liquid?
Thanks i'll give it a try.
Old Sep 22, 2003 | 06:51 AM
Carfunkel's Avatar
Carfunkel
From: Canterbury - A beautifu but overpriced rural setting in central NH
clear liquid?
Originally posted by F0rdF0rever
... four new tires ...What does everyone prefer?
Go with the black ones. Yeah, definitely the black ones.
Old Sep 22, 2003 | 01:51 PM
RedTaurus94's Avatar
RedTaurus94
clear liquid?
Black works really well for me, too....black tires match pretty much any color your truck might be. And make sure you get the round kind....trust me, you'll like them better.........
Old Sep 23, 2003 | 11:48 PM
Fordguy's Avatar
Fordguy
clear liquid?
Man we are a bunch of smart A$$es
But if you think about it you could get the square ones and after a bit they will end up round...
Old Sep 24, 2003 | 12:45 AM
ruggersford4x's Avatar
ruggersford4x
clear liquid?
hey man....dont know if you have a 2wheel drive or a 4 wheel drive. eitherwhich way, for an all around tire i really like the BFG ALL TERRIAN tire. my friends father had them on his dodge 2500 cummins. HE GOT GREAT MILEAGE OUT OF THEM. i personally use the BFG MUD TERRIANS though. excellent tire
