Question
Old May 21, 2018 | 09:41 PM
BradBryan58's Avatar
BradBryan58
Question
Im doing a leak down test on my rebuilt inline 6. Does the engine need to be warm for this?
Old May 22, 2018 | 07:32 AM
The Frenchtown Flyer's Avatar
You an do it cold or warm. I do mine cold. The biggest help to me is to compare cyl-to-cyl and track the numbers over the life of the engine so you can diagnose where a problem is.
On my home-built gage I see numbers for a fully prepared racing engine in the 3 - 8% range. On a stock fresh engine it is not uncommon for those numbers to range in the 20 - 25% range.
Old May 22, 2018 | 09:34 AM
BradBryan58
I just rebuilt this engine and I was getting 25 psi in most cylinders dry. However I just poured a little oil down the spark plug hole and got a reading of 5psi. Does this sound right? Which one is more accurate? and should there be any concern?
Old May 22, 2018 | 10:59 AM
Don't use oil. If you are using the stock ring pack with un-gapped ends, stock head bolts, bored / honed without a block plate, and a typical machine shop valve job I would expect around 25% as previously mentioned.
Old May 22, 2018 | 06:01 PM
old28's Avatar
old28
Just like to add a little more information to leak down test question. What would be a good psi reading for a fresh 300 rebuild with big valve 240 head, new hyper aluminum pistons, end gaped moly ring pack, machine shop performance 3 angle valve job, honed without block plate?
Old May 22, 2018 | 07:16 PM
john jamieson's Avatar
john jamieson
Originally Posted by The Frenchtown Flyer;
If you are using the stock ring pack with un-gapped ends, .
I'm a little confused. What are un-gapped ends? I thought you always measured the the gap in the rings and
adjusted it if needed.
john
diggerrigger
18
Jan 31, 2019 07:59 PM
Pkupman82
Nov 30, 2015 03:35 AM
GrantJ69
18
Oct 6, 2008 03:48 PM
Cruiseomatic
Dec 24, 2004 12:21 AM
FORD352V8
Nov 17, 2004 11:03 AM
