Coil spring sag, F250
Old 05-21-2018, 03:35 PM
smoky_diesel's Avatar
smoky_diesel
smoky_diesel is offline
72 F250 w/ 390, left front is 1/2" lower than the right. Looks like I could shim to balance but found some threads about Moog CC808 on F100s
https://www.summitracing.com/parts/mog-cc808
Given I have a 250 that has higher rate springs than a 100, is the 808 still a good choice? In addition to level left to right, I was hoping to raise up sagged out front end like other have done. I'm OK with softer ride and reduced load capacity, just don't want to lower it any more than it already is.
Thoughts? Other options?
Thanks
Old 05-21-2018, 04:33 PM
RIPbiker13's Avatar
RIPbiker13
RIPbiker13 is offline
I have a 69 F250. I swapped out the front end with a Crown Vic and no longer have need for the springs. The truck came factory with a 300 but was swapped out to a 351C in the early 70s. The springs had spacers on them, not sure why though. You're welcome to them. The truck rode level until I pulled it apart last year. I don't believe new springs cost a whole bunch, might be the best route.
Old 05-22-2018, 05:45 PM
smoky_diesel
Thanks for the offer. Where are you located? It's helpful to have location in your profile/avatar. Welcome to FTE.
Old 05-23-2018, 11:05 AM
smoky_diesel
Looks like the F250 can have a different and taller spring bucket on the frame. My truck (7500 GVW) does have the tall buckets and needs a spring with pig tails on both ends. Looks like 73-79 springs may work.
Post #30 here has some pics of both (Dents but similar)
https://www.ford-trucks.com/forums/1...250-2wd-2.html
ultraranger's 69 w/CC808
https://www.ford-trucks.com/forums/1...l#post15424705
So I would assume the 808's are too short and would not work. Perhaps Moog CC828 or 8646 but my need work to adapt lower mount.
Old 05-23-2018, 12:13 PM
RIPbiker13's Avatar
RIPbiker13
Fixed my profile (hopefully) to include where I'm located. Sorry about that.
I'm in Texas, near San Antonio. My truck had the shorter perches, because they don't look like the ones pictured.
Old 05-24-2018, 11:08 AM
smoky_diesel
Well I took the left spring out and the top isn't exactly a 'pigtail' like the bottom. It is more of a rectangle shape that fits into contours in the bucket. Note sure how well other springs would work. I corrected ride height with a spacer. See my thread for details https://www.ford-trucks.com/forums/1...ect-truck.html
ADOR
05-14-2016 09:12 PM
Ford_Six
WTB - Parts & other
07-18-2010 07:14 PM
martin441
09-22-2009 07:28 PM
scotjonscot
06-04-2009 12:05 AM
just-n-time
18
06-07-2008 07:59 PM
Quick Reply: Coil spring sag, F250
