Transmission woes
Old May 21, 2018 | 02:25 PM
‘67fairlaneGta's Avatar
‘67fairlaneGta
Transmission woes
Slight delay then loud slam when going from park to reverse or drive to Reverse.Truck is a 95 F150 4x, ifs, w/5.8. I replaced motor mounts tranny mount new driveline rebuilt rearend , replaced rear seal and fuild in transfer case. This symptom came on gradually over a month’s time. Took it back to the rear and shop, they say everything checked out fine? No metal in the fluid lash was good. I’m wondering if it might be the chain in the transfer case, or One of the solenoid stuck causing high pressure in reverse.? Any thoughts? Thank you
Piginabag
Dec 9, 2015 03:39 PM
saturn97sl1
Jan 28, 2014 11:04 PM
fishguts
Aug 13, 2012 05:07 PM
gunnerw
Mar 26, 2012 10:35 PM
fast97gt
1997 - 2003 F150
Feb 15, 2012 04:54 PM
