Need Help with Crankshaft ID
Thanks for the info.
Joseph
I figured it had been rebuilt sometime in the past. It came to me with the factory 4BBL "S" intake (I think with a '68 date code). I don't know if the intake is original to the engine, though (it came with both a 2BBL and 4BBL carbs in the box 'o parts). It also had a "long-tail" C6 transmission attached. I figured with all that, engine and transmission probably originated in a car, and got transplanted into my truck (a '67 F250 2WD) at some point.
I'll definitely need that checked into. A quick check measured the bores at 4.07", plus wear and tear. They would need to be bored at LEAST to 4.08". I also need to have the heads checked. The exhaust valve is sunk in about 1/8" on one cylinder. I don't know if this can be repaired, or if it's even worth repairing; these are only C4EA-G heads.
I didn't know that. I figured all of that would have to be replaced, so I chucked it in the circular file. I did notice that there were numbers stamped into the tops of the pistons; is this another sign of being a factory reman? I'll have to pull that stuff back out to check numbers.
Joseph
Joseph
Okay, seven of the connecting rods are C3EA-C. The eighth is C6EA-C. The one site I found so far said that the C3EA-C are the short rods for a 427, but it doesn't list anything for the C6EA-C. So, I'm still looking.
I didn't have too much time to check the crankshaft. I had to do a quick check with a couple of wood blocks on the work bench, but the difference measured out to 3-3/4", or thereabouts. Definitely over 3.5", though. I'll get a more precise measurement this weekend.
Joseph
Joseph
I checked the bearings tonight. Clevite for the main bearings, and Federal Mogul for the connecting rods. Both are 0.010 over (or under, depending on your point of view). I couldn't read the pistons; too much crud. Maybe this weekend.
Joseph
Yep, you're right. I got the letters swapped. They are C6AE-C and C3AE-C.
Joseph
Joseph
Best way to clean that crud off a piston is with a wire wheel on a bench grinder or a drill. Run a fingernail across the crank journals, if you feel ridges it'll need turning again. If they're smooth, you may get by with fresh bearings. But having a machinist mic them will tell you more acrurately.
Another odd realization with the disassembly was the engraved numbers on the connecting rods. The driver side matched the cylinder numbers: 5 - 6 - 7 - 8. But the passenger side was all screwed up: 2 - 1 - 3 - 3. Both #3 rods are C3AE. The deeper I dig, the more interesting my Frankengine becomes...
Joseph
I live in a small town, but I'm very fortunate that I have access to an excellent machinist. He's not a gung-ho, gotta-do-it-all type. He's very conservative, careful, and complete. I'll let him check everything out before I move forward.
Joseph
Joseph
Joseph
Joseph
One time a outfit I was wrenching for had a rod bushing come loose in the 331 truck engine, I dropped the pan and pulled the head from the bad side, jerked the piston and rod out, went to our used parts inventory and grabbed another 331 rod and had the engine back going in a few hours.
Didn't pay attention to what numbers where on the rod, it was the correct length and size so I used it.
Alvin in AZ
04-04-2009 01:14 AM
Jeff's Secretary
35
08-28-2007 08:28 PM
ceetwarrior
04-15-2004 09:30 AM
