Adding 1" to Carli 2.5?
#31
#33
They definitely offer the most functionality for the money. I think thats the way Im going to go.
#34
i have the 2* cams from the carli 2.5 in now, caster is a little low but camber is off. going to try adjustable cams tomorrow and get it as close as we can to how it was before and see if bump steer is alleviated.
i have the 2.5" ready lift drop bracket, im beginning to think i either need to add a drop pitman or revert back to factory bracket and an adjustable bar?
#35
Anyone on this forum running the PMF 3-link?
#37
spent some time on the interstate this morning, and everything about the truck felt stiffer. i dont know if radius arm angles are hurting me, if the balance of the truck is off, or perhaps what im feeling in the steering wheel is making me think its riding worse- but even the rear of the truck feels bouncier. hate to say it, but instead of throwing radius arms, track bar, dual stabilizers, etc at this to try to fix it, the 1" spacers are coming out.
#38
I want about 1" more on my Carli as well, but not sure...
or just go up to the 4.5, but $$
#39
#40
Even though a 1" spacer just lowers the axle down, it still may have some of the drawbacks that an inch of preload would on a coil over. Those 4" spacer lifts are the debil.
Also note, the further down, and away from level, that the radius arms go, the harsher the ride. You can fab radius arms all kinds of length and such, but the pivot points remain the same. If the front pivot point is lower than the rear pivot, the ride gets harsher. When I see 4" and 6" kits that use custom radius arms, but don't drop their mounting point level, they're leaving some ride quality on the table, in favor of ground clearance, simplicity, and looks.
#41
it crossed my mind that it may be the culprit, i just find it hard to believe that carli would package shocks with that little range of motion in them. its only an inch taller?
it feels stiffer not only on big bumps, but even the highway joints thats were essentially unnoticed before.
#42
#43
I spoke with Chris there and he was running a 2.5" spring lift with 37's and also ran the 1" daystar. He said he loved the ride. He now runs King coil overs in the front. I was chatting with him about his coil over kit - you lose travel as the shock cannot be as long as the standard spring/shock setup and you may need to preload them a lot to get the lift you need.
I'm going to run the Carli 2.5" springs. Just debating on 2" or 2.5" Fox shocks at the moment (from Accutune). I got the daystar 1" also so I anticipate running those to level it out. Ill be running 17" rims with 37's.
#44
How are things with your ride? I am currently collecting the parts for my lift. I went with Lewis adjustable radius arms - wow these things are beautiful and beefy. I also got Lewis's adjustable track bar.
#45
