Sponsored by: Auxito
Squeaky
Old Sep 19, 2003 | 01:29 PM
z 97ford1's Avatar
z 97ford1
Squeaky
Ok, With the truck parked I turn on the key start the engine and begin turning the wheel (left or right) and I get lots of squeaky noises that sounds like grommets.
Any ideas as to what this is?
Thanks,
Old Sep 19, 2003 | 01:34 PM
stepman's Avatar
stepman
Squeaky
Tie rod ends? Lift the boots and squirt some lube in them.
Old Sep 19, 2003 | 01:41 PM
z 97ford1's Avatar
z 97ford1
Squeaky
I think their sealed, aren't they?
Old Sep 19, 2003 | 01:55 PM
stepman's Avatar
stepman
Squeaky
What do you mean "sealed"? No grease fittings? We get this a lot on the newer Fords and we pull the rubber boot up a little and quirt some lube into the top of them.
Old Sep 21, 2003 | 09:32 PM
03f150man's Avatar
03f150man
Squeaky
the squeaking is most likely your pittman arm. Buy a needle fitting for your grease gun (about $4) , squirt some grease in thru the rubber cover and you will be fine for many thousands of miles. Wouldnt hurt to dab some sealant compound on the punture hole to keep water out. my 97 f150 has nearly 155,000 miles on it and still running the original pittman arm.
