Spring Problem.Mustang II ifs
Sickler1
The spring does look strange sitting between the upper housing and the lower control arm. I don't have an answer for you as I am more familiar with the Jag IFS that I installed in my 51 F1.
I am sure there are those familiar with Mustang IFS that will get back to you. I just wanted to bump your question to the top. Good luck.
Dan
Dan
My springs are rated for 500lbs. Haven't seen where I need 700lb springs.also price of your coilovers...$1 a lb per side or all together?
Actually $500 for a pair. https://www.fabquest.com/viking-perf...shock-kit.html
i called a couple companies and asked what spring rate they used for a total ifs kit. The consensus was around 600-700 depending on your motor
Received 4,132 Likes
on
It can vary a bit depending on the angle of the spring. Vertical would need a higher spring rate. You can roughly work it out. Assuming you have a travel of around 4.0 inches and you want it to compress around 1.5 inches + 1 inch preload. Weight on front wheels is around 2000 lb say or 1000 lb per side. 1000 / 2.75 = 400 lb/in spring. If angle of spring = 15 deg, then factor it down by Cos (15) therefore 400 x 0.966 = 386 lb spring (approx). If you have an adjustable spring seat you can play around with the preload to get the right height Just be sure you get the best possible estimate of weight on the front wheels.
on
on
