Accessory Fuse Problems
Old May 13, 2018 | 07:21 PM
1976hi-boy's Avatar
1976hi-boy
Does anyone know what the accessory fuse powers in a 1976 f250 highboy? I’m trying to track down what’s blowing the fuse. Thanks for your help
Old May 13, 2018 | 08:12 PM
Filthy Beast's Avatar
Filthy Beast
I believe one ACCY would be HOT in RUN....that would power the radio, etc.....Don't know which one, if you have two....? Mebbe don't limit your pokin' around to just the ACCY slot on the ignition switch,,try the RUN one too.
It's easy to confirm for yourself. Just test continuity (BEEP) between the BATT terminals and any given terminal ------ different positions of the key switch.
Hope you have a manual.....the wiring diagrams are gettin harder and harder fer me to see, but you young'uns should be able to tell gnat crap from a splice across a page at 20 feet.....
Old May 13, 2018 | 10:05 PM
1976hi-boy's Avatar
1976hi-boy
Haha ok thanks. I just did a smoke test on it because I tried following everything I could. I guess when I did that it burnt up whatever was grounding out so I guess I’ll see what happens haha
Old May 13, 2018 | 10:43 PM
Filthy Beast
Shooot.....the smoke test....yeah, I'd forgotten about that one....Hope you managed to capture some to put back later......
On a more serious note, were you harmed? And is your vehicle not a piece of burnt marshmallers?
Do you remember what circuit you were testing when you let the smoke out of the wires?
Old May 13, 2018 | 11:09 PM
1976hi-boy's Avatar
1976hi-boy
Hahaha I just connected the two ends where the fuse goes in with a piece of wire to see where it was shorting out
Old May 13, 2018 | 11:22 PM
Filthy Beast
What did it read on the fuse block where you were diddlin'?
You just might have found out the illness......as you well know....
kr98664
Nov 15, 2018 05:06 AM
tx2sturgis
28
Sep 29, 2015 06:57 PM
RL250
Apr 5, 2014 06:00 PM
IamToyoftherm
2004 - 2008 F150
17
Sep 8, 2012 10:23 PM
triskit16
Apr 21, 2009 11:17 PM
