Decoding a warranty number?
Old May 6, 2018 | 10:43 PM
Black Helmet's Avatar
Black Helmet
Hey!
got another old Ford I’m interested in, but was wondering if I could get some help decoding the warranty number and other stuff on the tag? Supposedly it’s an old govt. vehicle, has a short service box on it and a large front bumper and monster winch. Thanks!
by https://www.flickr.com/photos/88902971@N02/, on Flickr
Old May 7, 2018 | 01:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Black Helmet
Hey! Got another old Ford I’m interested in, but was wondering if I could get some help decoding the warranty number and other stuff on the tag?
Supposedly it’s an old govt. vehicle.
Not.
F26 = F250 4WD
B = 300 1V I-6.
R = San Jose CA Assembly Plant.
639689 = 1965, assembled January 1965.
120" Wheelbase.
T = Light Beige.
F260 = F250 4WD; 6,800 lbs. GVWR
D81: D = Light Beige Crush Vinyl & Medium Beige Ladder Pattern Woven Plastic // 81 = 81B Custom Cab.
N = New Process 435 4 Speed Manual Transmission.
B5D:
B5 = Spicer/Dana 60 Rear Axle / 4.56-1 / Limited Slip / 5,200 lbs. Rear Axle Capacity.
D = Spicer/Dana 44-6HDF Front Driving Axle / 4.56-1 / 3,500 lbs. Front Axle Capacity.
6,800 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3,600 RPM
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
If this was a government vehicle, the DSO code would have been 83, it most likely would have had a 240 1V I-6, Limited Slip rear axle very doubtful and it would not be a Custom Cab.
Governments are notorious cheapskates, usually bought the cheapest 'stripper' trucks, without any extra cost options like radios, heaters, outside mirrors, seat belts, Limited Slip, Custom Cabs.
The fact that it's an F250 with a 4 speed and 4WD is also suspect. El cheapo governments usually bought F100 2WD 240 I-6's with 3 speed M/T and were short bed Flareside pickups.
Old May 7, 2018 | 11:32 PM
Black Helmet
F26 = F250 4WD
B = 300 1V I-6.
120" Wheelbase.
T = Light Beige.
B5D:
Awesome thanks! I suppose it’s possible a govt agency bought it used (the one I work for does that once in a while) but either way that dose t matter much to me. In some of that info does it say to you that it came with a bed, without a bed, or did Ford offer a stock utility (with cabinets) bed? Thanks again!
Old May 8, 2018 | 02:53 AM
NumberDummy
Awesome thanks! I suppose it’s possible a govt agency bought it used (the one I work for does that once in a while) but either way that doesn't matter much to me.
There's no way to know what type of bed the truck came with. A utility bed would have been installed by an aftermarket body maker, as Ford never offered one.
Old May 8, 2018 | 11:01 AM
Rick Bensco's Avatar
Rick Bensco
I too just got an old 1966 f-250 yet the title said 1965 Plus I was trying to figure out if it is a camper special. It had 3 gas tanks and a spot for 2 batteries. f25yr777688 129 WB color h f 250 body m81 trans A B4 axle7500 max gvw 172 cert.net hp 4000 r.p.m. 72
Old May 8, 2018 | 11:42 AM
NumberDummy
Originally Posted by Rick Bensco
I just got a 1966 F250, yet the title said 1965.
Plus, I was trying to figure out if it is a Camper Special. It had 3 gas tanks (not original)* and a spot for 2 batteries (not original).*
F25YR777688 / WB: 129 / COLOR: H / MODEL: F250 / BODY: M81 / TRANS: A / AXLE: B4 / MAX GVW LBS: 7500 / CERT NET HP: 172 / RPM: 4000 / DSO: 72
F25 = F250 2WD
Y = 352 2V
777688 = 1966 (1966 serial number range: 732,001-914,000).
129" Wheelbase.
H = Sahara Beige.
F250 2WD, 7,500 lbs. GVWR
M81: M = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
B4 = Dana 60 Rear Axle / 4.10-1 / Limited Slip / 5,200 lbs. Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Does the "pink slip" have year first sold and year model printed on it? Since this truck was assembled in 1965, it might have been registered as such.
*The saddle tanks and dual batteries are not genuine Ford, were added by a previous owner or an RV dealer.
The only factory installed fuel tank is the in-cab tank and no truck until 1973 was available with dual batteries.
There are no codes within the VIN or stamped on the Warranty Plate that identifiy a Camper Special.
Front fender emblems have Camper Special plastic inserts. Tail lamp harness has an extra feed wire for the pigtailed wire harness/plug used with camper clearance lamps.
No extra feed wire, it is not a Camper Special.
Amphihauler
Aug 26, 2016 01:53 PM
PACrewCab
Jul 24, 2016 05:47 PM
Codo
Oct 29, 2012 04:27 AM
dacampeau
13
Apr 12, 2012 08:36 PM
leedog13
Apr 13, 2009 11:20 PM
