Pinion yoke
Wanted
Drivetrain
  • Expired
  • Price
    $0 - $50
    • Trade
  • Location Christmas Valley, OR, 97641, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford F-250 HD 1990 - 1991
Description:
wtb pinion yoke for a 10.25 sterling rear diff. i'm not sure what years fit. but i do know there is a newer model, than the one i have and i believe it's like a half inch longer. this is for a 1990
Old May 8, 2018 | 10:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Hanks other son
WTB: Companion flange (pinion yoke) for a 10.5 sterling rear diff. i'm not sure what years fit. but i do know there is a newer model, than the one i have and i believe it's like a half inch longer
10.25" or 10.50" Sterling?
Old May 8, 2018 | 07:09 PM
Hanks other son's Avatar
Hanks other son
thank you for the reply, i believe it's a 10.50 but i'm not sure and my truck is 23 miles from here, i should be over there this weekend and will check it out. this time of year i'm swamped with work and trying to get two projects up and running. thank you Bill
Old May 10, 2018 | 04:06 PM
69 broncosport's Avatar
69 broncosport
10.25" sterling is pre 99, 10.50" is 99-present I believe, SRW only Dually's have a Dana 80
Old May 10, 2018 | 05:12 PM
NumberDummy
Sterling 10.25"
Upper pic: Parts list #258 .. See: E5TZ-4851-A & E7TZ-4851-A
Center pic: Specification measurements.
Lower pic: Look at first two entries for the above two part numbers..
Old May 10, 2018 | 10:33 PM
Hanks other son
your right it must be a 10.25 sterling, so how do i tell which of those part #s is the right one. i don't have the old yoke, previous owner took it off .
Old May 10, 2018 | 11:08 PM
NumberDummy
TWO different sizes of U-Joints. E4TZ-4851-A uses a 1330 joint; E7TZ-4851-A uses a 1350 Joint.
Here is the u-joint chart that shows the difference (Edit: Grrr! 1350 specs not listed) . Compare the specs of the front u-joint with yours to see if it matches the 1330 joint (1st entry).
Old May 14, 2018 | 09:56 PM
Hanks other son
well that also present's another problem as I have no drive line or yoke for the rear, any chance the front drive line is the same as the rear ? because that i do have. and i could measure those ujoints
Old May 14, 2018 | 09:58 PM
Hanks other son
