Fuel bowl cleaning
Old 05-03-2018, 11:26 AM
Broszd's Avatar
Broszd
Broszd is offline
Fuel bowl cleaning
I have a 1997 f350 7.3 and replacing fuel filter. I noticed there is grime and what looks like some kind of gel in the very bottom of the fuel bowl. Is there some kind of trick to remove the long plastic pickup tube so I can get to the bottom of the fuel bowl? I see a nut at the base but even my deep well sockets are not long enough to reach it and I'm afraid I'm going to break it with pliers. I've also heard its a reverse thread but it won't budge
Old 05-03-2018, 01:21 PM
pwjackson42's Avatar
pwjackson42
pwjackson42 is offline
You should be able to twist it out, I had mine out to clean the bowl awhile ago. If I remember correctly it was pretty snug. I am pretty sure it is reverse threads though.
Old 05-03-2018, 02:30 PM
dclack's Avatar
dclack
dclack is offline
Use a crow foot wrench and extension.
Old 05-03-2018, 02:43 PM
farmert's Avatar
farmert
farmert is online now
This /\ /\ /\ and it is left hand threads.
Old 05-04-2018, 06:33 PM
Broszd's Avatar
Broszd
Broszd is offline
thanks got it out and everything replaced but now something wierd is happening. Truck takes long time to start and has basically no throttle. Will idle at about 600 and little rough put pedal to floor and will rev to about 800 and that's it. Let off pedal and very rough idle and tries to die. I'm about at my wits end here
Old 05-07-2018, 03:35 PM
knottyrope's Avatar
knottyrope
knottyrope is online now
did you put the regulator back in right?
possible the wiring harness has a break in it over the drivers VC and only running on one bank
ohm it all out
Old 05-07-2018, 10:44 PM
Broszd's Avatar
Broszd
Broszd is offline
Regulator? There was just a pickup tube, a plate, and a heating element
Old 05-08-2018, 07:42 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Regulator is on the side of the bowl.
Old 05-08-2018, 01:34 PM
knottyrope's Avatar
knottyrope
put a tire pressure gauge on bowl Schrader valve while running to test for pressure
Old 05-08-2018, 06:47 PM
867.309's Avatar
867.309
867.309 is offline
I saved these links for the fuel filter housing:
7.3L Power Stroke Fuel Filter Housing Removal & Installation Procedures
7.3L Power Stroke Fuel Filter Housing Rebuild Procedures
I might buy a new one if mine looks too crappy. So far it looks good.
Old 05-08-2018, 07:01 PM
97-psd's Avatar
97-psd
97-psd is offline
Did you clean the screen on the inside of the fuel bowl while you were in there?
Old 05-10-2018, 12:50 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Lightbulb
I was going to ask that. The regulator is the fuel pressure regulator = FPR.
Is the new fuel filter OEM? The filter has to press the valve in the stand pipe when you put the cap of the fuel bowl. If it is a little longer wont do that.
golfnut324
12-27-2016 02:10 PM
fordman67
10-09-2012 12:03 AM
robjs111
37
05-04-2009 04:36 PM
PSDLOVER
03-24-2005 04:00 PM
welder2000
04-14-2004 02:02 PM
Quick Reply: Fuel bowl cleaning
