T4/SXE vs. KC38R - Decision has been made...
Old 09-20-2018, 10:47 AM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
Originally Posted by akcooper9
I'm on my 3rd down pipe....
First down pipe was clocked wrong, second down pipe was clocked right but where the flange for the turbo was welded on was cut to short. Third one is correct (although I do have a slight jog in my flex pipe).
I hope a year later Carson has things figured out with his pipe bender.
Mine fits great (I ended up with the 3" do to confusion between me and DP when I ordered it.)
  #332
Old 09-20-2018, 01:41 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
That had to be a little bit frustrating!
Stewart
  #333
Old 09-20-2018, 01:42 PM
akcooper9's Avatar
akcooper9
akcooper9 is online now
Stewart
Extremely but Carson was great, made it 100 percent right. Im lucky my trucks isnt a daily driver so that helped as well.
But on the bright side, Im really good at installing CSD T4 kits
  #334
Old 09-20-2018, 01:49 PM
Stewart_H's Avatar
Stewart_H
Wanna take a trip out to Cali and hook a brother up? I just gotta register my truck in a county that doesn't do smog inspections.
You guys running these upgraded 7.3's that can hang with the modern diesels can make a man very envious!
Stewart
  #335
Old 09-20-2018, 02:01 PM
The Brad's Avatar
The Brad
The Brad is offline
Stewart
I’m happy to oblige if you wanna drive a few hours south.....with beer!
  #336
Old 09-20-2018, 04:18 PM
Sous's Avatar
Sous
Sous is online now
Received 4,481 Likes on 2,863 Posts
Akcooper9 has offered his installation services many times. I thanked him each time and told him I didn't want to turn into cousin Eddie from National Lampoon's Christmas.
I look forward to getting the install done and testing it thoroughly during our trip around the country next spring.
We are headed back to the Washington state area and going to take 60-90 days to go round trip. I suspect this time will be dramatically different than the last trip in 2015 when the truck was 100% stock.
  #337
Old 09-20-2018, 04:36 PM
Wes444's Avatar
Wes444
Wes444 is offline
Received 1,144 Likes on 653 Posts
You'll definately notice a difference stock vs mods Sous, although you may have gotten too accustomed to modded in 3 yrs to remember the stock starting point as well. I did the basic FTE mods in sig 1 at a time in between our camp trips and could tell a difference towing with each one. Going T4 will probably be a huge difference for you. I know I'm awaiting your b4 and after torque log comparisons.
Hoping to see you pick up 2 mpg to make it easier to convince a spring purchase to my wife
  #338
Old 09-20-2018, 07:13 PM
565edge's Avatar
565edge
565edge is offline
Downpipe offset
  #339
Old 09-20-2018, 07:15 PM
565edge's Avatar
565edge
565edge is offline
Behind crossmember.
  #340
Old 09-20-2018, 07:23 PM
565edge's Avatar
565edge
565edge is offline
Looking toward front of truck.
  #341
Old 09-20-2018, 08:26 PM
DavenTn's Avatar
DavenTn
DavenTn is offline
Did your truck ever have the heat shield? I don't see it in the picture.
  #342
Old 09-20-2018, 08:43 PM
565edge's Avatar
565edge
565edge is offline
Not sure. My exhaust was routed on the other side of framerail when I bought the truck and I just changed it back like factory. I didn't move a heat shield
  #343
Old 09-21-2018, 12:22 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Is that heatwrap or a coupling to accomodate the offset of DP to rest of exhaust plumbing?
  #344
Old 09-21-2018, 09:57 AM
565edge's Avatar
565edge
565edge is offline
The downpipe is ceramic coated and then I heat wrapped the exhaust right past the trans.
  #345
Old 09-21-2018, 02:04 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Received 3,423 Likes on 1,797 Posts
565Edge, is your frame cracked?
It could be just a squiggle in the frame coating, but thought you might want to take a closer look in case that was a crack initiation site, which appears to follow the same modality (flange edge to relief at hole) as a frame would typically present cracking, and which happens to be located in the area where Ford reinforced the frames in later model years.
Just helping keep you on your toes.
Quick Reply: T4/SXE vs. KC38R - Decision has been made...
