P1832 questions
Old Apr 30, 2018 | 12:29 PM
Jschon's Avatar
Jschon
P1832 questions
To start off, 02 F250 CC w/ 315,000 miles. Truck runs and drives well, and shifts into and out of 4x4 with the in cab switch.
Check engine light came on a couple of weeks ago so I pulled the codes with ForScan. I got a P1832- Transmission Transfer Case 4wd Solenoid circuit failure.
The truck seems to pull better when in 4hi but I can;t confirm that it does shift, I can hear a solid clunk and a noticable difference in 4lo. The only other thing wrong is that Transmission range Sensor needs to be adjusted but I haven't gotten around to it yet.
I don't know where to start with the diagnostics, any suggestions?
Old Apr 30, 2018 | 03:50 PM
Arizona97's Avatar
Arizona97
Curious, Subscribed.
Old Apr 30, 2018 | 03:57 PM
Walleye Hunter's Avatar
Walleye Hunter
I don't know about the code number but mine always gives me that same fault reading when I scan it. My 4WD works the transfer case but I have manual hubs. Until it breaks I can't fix it.
Old Apr 30, 2018 | 04:53 PM
jhl3's Avatar
jhl3
Mark and OP, I get the same code on my e99. There has not been an issue for the last 100k miles with the code present...knock on wood. There was a thread a while back where the transfer case (TC) gave up and crapped the bed due to it being an early model TC which had some lubricating issue around the input shaft or shift forks IIRC which would apply to Mark and me but not the OP unless his TC has been swapped out and replaced with an earlier TC.
Old May 1, 2018 | 08:51 AM
Jschon's Avatar
Jschon
I'm going to try and find the solenoid in question and try to see if I can confirm if it's working. Does anyone know what kind of voltage should be getting to it or what fuse it runs off of?
Also, does anyone happen to know what the part number for that solenoid is? i don't want to replace it yet but I would like to start pricing it in case it comes to that.
Old May 4, 2018 | 01:33 AM
Jschon's Avatar
Jschon
Sorry for the late update. I got distracted by a leak in the oil cooler but, that's another story entirely. I did some poking around and I can't find the solenoid. I found the transfer case **** motor which is on the transfer case. No solenoid in sight, does anyone know where this thing is?
crisk
Apr 17, 2015 11:39 AM
RIKIL
Dec 10, 2014 09:39 AM
breakout99
Dec 21, 2011 08:03 PM
SoArkSI
Nov 5, 2005 08:43 PM
expydriver
Apr 24, 2003 10:30 AM
