Slip yoke
Old Apr 29, 2018 | 01:12 PM
1Lowflyer's Avatar
1Lowflyer
Slip yoke
How do you know what slip yoke goes on the transmission? I have a 3 speed OD with 16 spline shaft X 1.17" diameter.
Thanks,
1Lowflyer
Old Apr 29, 2018 | 04:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Assuming you have a 53 - 56 truck.... It's the same spline and u-joint as a 3-sp non-OD trans. Original P/N B5C-4841-A. If you can't find one, Blue Oval Parts has them made to order for $370; some people use the slightly shorter Powerglide yokes:
Dana Spicer 2-3-1331X Transmission Slip yoke 16 spline for 1955 to 1964 Chevy Powerglide Transmission 1310 Series
Old Apr 30, 2018 | 08:57 AM
1Lowflyer's Avatar
1Lowflyer
Ross,
I'm actually not sure of year of the transmission since I got it of of an 292 Y-Block that I found in a field back in 1973. The spline matched the 3 speed transmission that was on the original flat head V-8 that I no longer have. I later put a 352FE with the Fordomatic and got rid of the old yoke in about 1975. Now I'm marrying the 3 speed OD to the 352FE and pitching the Fordomatic so, I need the yoke that fits the 3 speed OD. It looks like highlighted one you show in your post is the right one..
Thanks,
1Lowflyer
Old Apr 30, 2018 | 02:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/66 F100 115" wheelbase 240/300/352 3 O/D: C5TZ-4841-E .. Slip Yoke, 1280 U-joint, 28 splines.
1957/60 F100 110" wheelbase & 1961/64 F100 114" wheelbase 3 O/D 272/292: B7C-4841-A .. Slip Yoke, 1310 U-joint, 28 splines.
1953/56 F100 3 O/D & F/M: B5C-4841-A (replaced TAAA-4841-B) .. Slip Yoke, 1270 U-joint, 16 splines.
wibblequikit
17
Dec 22, 2014 06:16 AM
charliehorse68
Feb 18, 2011 06:49 PM
f100rescue
Aug 3, 2009 02:29 AM
onepeiceatatime
Apr 13, 2007 01:09 AM
