Suggestions
Old Apr 28, 2018 | 10:16 AM
Stilwill 51 f1's Avatar
Stilwill 51 f1
Suggestions
I have 51 f1 that I had the mustang 2 front end put on, the problem I have is that, the wheel bearing dust cap sticks out a little to far and the original center cap won't fit. The wheels are a bullitt style off a mustang, anyone has suggestions to fix the problem.
Old Apr 28, 2018 | 07:57 PM
topmoo's Avatar
topmoo
Probably nothing you can do other than find some deeper caps or change you wheels. Maybe someone here knows about some other caps to fit your wheels so I will bump this up the board.
Old May 1, 2018 | 12:10 AM
OK F1's Avatar
OK F1
I have a Heidt's Mustang II front end on my 50 F-1. I put a set of Bullit style wheels on it because the lug pattern changed and I needed to make it a roller. Yes, the dust cap sticks too far into the wheel, but a bigger problem is the high positive offset of the wheel. There is no way I could use the wheels without sacrificing more than a third of my turning radius. The inside lip of the wheel contacts the upper control arms long before I reach the steering stops. This may be something to look into before you spend too much time looking for a workaround on the center caps.
Unless you have somehow avoided that same problem, new wheels may be your only real option anyway! Sorry to be the bearer of bad news
bunchoftrucks
May 16, 2014 08:12 PM
robertr
Jul 22, 2011 04:35 PM
willymakeit
Aug 30, 2009 07:36 PM
custom cabby
Feb 20, 2007 10:26 PM
thatdude
Apr 2, 2002 08:09 PM
