72 fuel return line
Old Apr 23, 2018 | 02:01 PM
Davektm's Avatar
Davektm
72 fuel return line
Hey guys,
I'm getting ready to reinstall my engine and tranny and sorting out all the lines. My truck has a fuel return line running back to the in cab tank, do I need the return line? I'm running an electrical pump if it makes any difference and have swapped out the old Holley 2 barrel for an edelbrock 4 barrel and can't remember where the return line came off the 2 barrel 😬
Any my help very much appreciated
Old Apr 23, 2018 | 03:08 PM
Brian1971f100's Avatar
Brian1971f100
That is a fuel vapor recovery line. It should go to a charcoal canister located in front of the passenger front spring on the inside of the frame rail. Should have had some sort of line that ran to the air cleaner or the intake.
HIO Silver's Avatar
HIO Silver
Originally Posted by Davektm
Hey guys,
I'm getting ready to reinstall my engine and tranny and sorting out all the lines. My truck has a fuel return line running back to the in cab tank, do I need the return line? I'm running an electrical pump if it makes any difference and have swapped out the old Holley 2 barrel for an edelbrock 4 barrel and can't remember where the return line came off the 2 barrel ��
An OE 2V application won't have a return line with a mechanical pump.
A return line would be present (generally) with EFI or a carbed 4V application with a high-pressure electric fuel pump and by-pass fuel pressure regulator.
... we would be interested in more detail what electric pump you installed so we can provide better feedback. Pics are welcome too.
Old Apr 23, 2018 | 04:05 PM
Davektm's Avatar
Davektm
It's an edelbrock pump that was on when I got it and ran with the two barrel. I've binned the charcoal filter and that could well be where the vapour line ran from. Is there any reason I can't just plug up the tank connection and ditch the vapour line?
Old Apr 24, 2018 | 03:31 AM
Davektm's Avatar
Davektm
Having looked at this I may do away with the charcoal filter and vapor line and run a hose down the chassis to the rear of the truck with an inline breather like the one below
Old Apr 24, 2018 | 03:32 AM
Davektm's Avatar
Davektm
Old Apr 24, 2018 | 07:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1972 F100
I see you live in the UK, but do you know where the truck was sold new?
1970/72 F100's sold new in California (CA) have the Evaporative Emission system (see pic below). Other states may have mandated it as well.
DSO code stamped on the 3rd line-far right of the Warranty Plate, riveted to the left door face below the latch. If the code is 71 or 72, it was sold new in CA
Click on pic twice to enlarge it. 9D653 shown at lower left is the charcoal canister.
Old Apr 24, 2018 | 08:19 AM
Davektm's Avatar
Davektm
I got it from Texas but will check the plate, I see no need for the canister and it's rough shape which is why I want to delete it. Going to go to an under bed tank next winter anyhow.
gwcrutch
Aug 30, 2023 02:17 PM
69-er
Mar 21, 2017 10:00 PM
Kelley11
Dec 30, 2014 09:34 PM
HighdefJoe
Sep 20, 2008 11:09 AM
