Brake pad wire spring
Old Apr 23, 2018 | 09:37 AM
gmammakn's Avatar
gmammakn
in the process of doing a ton of stuff to the EX. Pads and rotors still good. When I took the pads off the wire prong broke, of course, but the tip remained in the hole on the brake pad.
So so what is the purpose of these things anyway?
Old Apr 23, 2018 | 09:45 AM
96firephoenix's Avatar
96firephoenix
They are a return spring to keep the pad from dragging on the rotor. Reduces brake heat and noise.
Not 100% essential, but will extend the life of your pads and rotors.
Old Apr 23, 2018 | 04:45 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You definitely want new springs. You should be able to buy a "hardware kit" from one of the parts stores or from RockAuto.
Old Apr 23, 2018 | 04:55 PM
gmammakn's Avatar
gmammakn
The problem is the holes where the springs go are filled with old springs
Old Apr 23, 2018 | 05:35 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Tweezers? Tiny needle nose pliers? LOL
Old Apr 24, 2018 | 01:27 PM
96firephoenix
Maybe a can of keyboard cleaner? just fine-gauge compressed air at the end of the day.
TNT
Sep 17, 2021 08:14 AM
texastech_diesel
Apr 17, 2011 09:47 AM
Storm
Jun 23, 2007 03:58 AM
